crappy 97 civic wont pass inspection
ok guys im in need of a good mechanic or some gas and a lighter.... i purchased the car and had an engine swap done on it... now comes time to inspect it and the check engine light is on.... i think when the swap took place the mechanic put an older engine in it so the engine might not be obd2... anyhow the car runs great but i am getting 2 codes from the computer... one is p1337 and the other is p1509... does anyone have any ideas?? thanks
Re: crappy 97 civic wont pass inspection
iac valve is located on the throttle body and has coolant lines going into it. its for idle air control. if it failed, you can try to take it off and clean it, but it could just have died and needs a new one. csf i have never heard of.
Sounds like some of the wiring wasn't done properly on the swap.
P1337 - CKF No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit
P1509 - Could be any of the following...
IAC valve mechanical malfunction
Throttle body clogged port, improper adiustment
lntake manifold gasket leakage
Intake air hose loose leakage
Vacuum leak
ECT sensor incorrect output
Throttle Position sensor incorrect output
Vacuum leak
yeah... im stumped by the ckf thing... as for the iac, it just started hunting for idle and is doing so between 1500 and 2000 rpm's... if i unplug the throttle position sensor it stops and idles fine???
Touge
Ottawa
Apr 26, 2015 11:57 PM
NeoMagus
Nov 7, 2001 10:10 PM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
