help- clunking noise
Old Apr 24, 2009
Dexters96's Avatar
Dexters96 is an unknown quantity at this point
I just purchase my 96 civic coupe EX and was told that my car had coil overs installed. I have not looked to confirm this but I have noticed that there is a faint clunking noise when I hid a bump and sometimes when I shift. is this because the coil overs or should i be looking for another problem. my noise is not that loud like EM1FTW's but sounds like it could be the same problem. The drives straight with no wobbles or shacking even at high speeds ( took it up to 100 mph to see what it could do - very fun). Any ideas or direction would be appreciated. Thanks.
Old Apr 25, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: help- clunking noise
It could easily be a spring rubbing on itself depending on the spring rate/type/installation. Or maybe they were not locked in place, therefore a sleeve is loose. Get under it and check it out right away.
Also check the car's front upper control arm mounting bolts (one on the front and back of the strut towers). If one of those is loose an odd clunking noise will happen and it's a simple fix.
Old Apr 25, 2009
Dexters96's Avatar
Thanks for the info.
Old Apr 25, 2009
they might not have installed them properly. or something suspension related may have worked itself loose.
Old Apr 26, 2009
Dexters96's Avatar
well i took it to a shop real quick to see if it was a serious problem. They told me struts are bad but they didn't even take it into the garage, they just drove it. the car does seem to bounce a little to much so maybe the shocks are bad. when the weather clears up I will get under it and check it out myself, as I don't have a covered area to work on it right now. Thanks for the insight.
what does it mean to lock in the shocks. not real familiar with installing shocks.
Old Apr 27, 2009
ScottDR's Avatar
What I meant about locking was the coil overs have adjustable rings in which the car is raised or lowered (the spring perch). If those were not tightened or locked in place they could create noise as things move around.
Old Apr 27, 2009
97h22civic's Avatar
97h22civic is an unknown quantity at this point
my locking ring was loose on mine and made the same noise then readjusted them and tightened them and it fixed problem..
Old Apr 27, 2009
ScottDR's Avatar
See?
Old Apr 27, 2009
Dexters96's Avatar
Awesome, I should be getting underneath the car today or tomorrow. let you know what I find. thanks again.
Old Apr 27, 2009
Dexters96's Avatar
So I got under the car today and saw my problem. First the coil overs look like a no name ebay special. second the struts are leaking. So now I will be looking for some good struts to put on my car. Any Ideas?
Old Apr 27, 2009
tokico HP blues
Old Apr 27, 2009
ScottDR's Avatar
Depending on spring rate, KYB AGX or Koni yellows.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tooly145
Sep 5, 2015 01:05 AM
jpat21
Sep 3, 2015 11:32 PM
