Clutch acting strange
Old Oct 11, 2008
tywaugh's Avatar
tywaugh is an unknown quantity at this point
Hey guys and girls,
I am new to this site but am hoping someone can help me with a problem that I am having with my 96 hatch civic.
Lately that when the car is cold I push the clutch to the floor put in 1st gear and as I release the cutch it comes about half way out before it starts to disengage and I can hear and feel the car starting to move forward.
After the car has been driven approx 10 minutes and is warmed up I do this same thing. I push the clutch to the floor put it in 1st gear and as soon as I start releasing the clutch the car starts to move. I don't remember this happening before so I am going to assume it just started happening. The only thing that happened lately is that I had the transmission fluid topped off, it was 1/2 liter low. The mechanic topped it off with 10w30 motor oil.
Any insight would be much appreciated.
Ty
Old Oct 13, 2008
sql_civic's Avatar
Re: Clutch acting strange
Honda recommends Honda Manual Transmission Fluid not 10w30 for your vehicle. Check your owners manual. I would drain the whole ting and do it right.
Check the fluid level in the clutch line resovoir. It's next to the brake master cylinder. Make sure it filled with brake fuild to the proper level.
Old Oct 15, 2008
tywaugh's Avatar
Thanks for the reply. I will check that.
I did notice that after it started happening again I will pump the clutch a few times put it back in gear and it works normal so it is obviously something to do with the clutch mechanism.
Thanks again
Old Nov 5, 2008
Kamikaza's Avatar
Kamikaza is an unknown quantity at this point
HMT fluid is very very similar to engine oil. I've seen guys using it for years without any problems. Check the hydraulic fluid for the cluch. It sounds like that's the problem.
Old Nov 8, 2008
sql_civic's Avatar
Yes HMT fluid is very similar to engine oil so you can use oil temporarily in an emergency. HMT fluid does have certain additives that enhance its performance.
Old Nov 13, 2008
ekcivic719's Avatar
ekcivic719 is an unknown quantity at this point
the 10w30 oil isnt good for ur tranny use HMT and u should bleed the clutch with sum DOT3 brake fluid until the fluid turns clear in the resevoir that should sove your problem
mrohitredd
40
Sep 9, 2017 12:03 PM
i drive
Sep 14, 2015 01:56 PM
JetsterDajet
Aug 15, 2015 08:07 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
