98 ex speedometer problem
Old May 13, 2008
LuciouzSOHC's Avatar
LuciouzSOHC is an unknown quantity at this point
Unhappy 98 ex speedometer problem
I just got my civic in Jan. everything was workin well until i took it for a long ride. Once i arrived, my speedometer died out on me. it works when it wants to for about 10 min then dies out again. i heard this was a common problem for Hondas. just wondering if anyone has aver heard or had the same problem... any response is good. thnx
Old May 20, 2008
sql_civic's Avatar
Re: 98 ex speedometer problem
Check rhe connection at the vehicle speed sensor (VSS). The output of that sensor drives the speedometer. It's on the tranny near the firewall plugged in going straight down.
Old Jun 5, 2008
CAPT CAVEMAN's Avatar
CAPT CAVEMAN is an unknown quantity at this point
I had a very similar problem. Mine would work sometimes, and not others. Quit somtimes while I was driving, and start working again for no appearant reason.
It ended up being that the wire coming through the firewall from the speedsensor to the speedometer, had rub the insulation off over time,and would make contact with steel, causing the speedo to not work. That's what the service guy told me.
I got charged for the diagnostic check, and that was it. He said they just spliced the wire and repaired the insulation. I'm guessing the wrpped it in electrical tape. But it has worked since then, and if it happens again, I'll know where to look.
youngm
Jun 4, 2015 10:19 PM
izdman
May 19, 2015 03:43 PM
One_PeeJay
May 17, 2015 05:31 PM
Chronic_issues
May 8, 2015 05:40 PM
dragonsblood
Apr 27, 2015 12:28 PM
