Cluster Swap
Old Mar 10, 2008
DX5spd's Avatar
DX5spd is an unknown quantity at this point
Cluster Swap
Ok i would like to swap in a 03-05 red cluster into my 96 but has anyone done this and is it worth it. I really like the look of those clusters. Any info would be nice. Thanks
Old Mar 10, 2008
TRIZ's Avatar
Re: Cluster Swap
I havent heard anyone doing this, so you'd be the first. You need to repin the wires from your existing cluster into the two harness plugs on the back of the 03-05 clusters. Its not too hard. But after you do that, it should work. I dont know if you'd have an issue with the signal/voltage sent to the needles- as in if they would read correctly. Its not a hard job to repin, if your up for it- def try it.
Assuming they are not the same shape, you need to make a custom bezel for the gauge cluster- which is just some plastic or fiberglassing.
Old Mar 10, 2008
DX5spd's Avatar
Re: Cluster Swap
Yea i figured nobody tried it i searched for awhile but found nothing. I am actually gonna give it a try once i get a 03-05 cluster so ill write up a diy with tons of pics. the only thing that has me worried is if the odometer would function right or at all. anyone got a wiring diagram for the plugs that go into the cluster this would help me out alittle ill pick up a cluster by the end of the month im broke. and if anybody has a 03-05 cluster for cheap let me know i would like to do the red cluster but any 03-05 cluster will work but it needs to have a tach
Old Apr 24, 2008
lobomic's Avatar
lobomic is an unknown quantity at this point
Re: Cluster Swap
well i hav a 96 civic dx (no tach in the gauge cluster) and i want to swap it with a ex gauge cluster(tach included in cluster). any advice? any additional wiring? this shouldn't b too hard right? :s
Old Apr 24, 2008
TRIZ's Avatar
Re: Cluster Swap
Basically get the wire diagrams for each cluster and see if any wires have changed. If they have, check out 01hondercivic's DIY on the cluster swap for a video on how to re-pin the connectors.
Old Apr 24, 2008
Re: Cluster Swap
it prolly will swap if its from the same year of car
Old Apr 24, 2008
lobomic's Avatar
Re: Cluster Swap
aight kool i'll chek it out, thnx for the intel
Old Apr 24, 2008
sql_civic's Avatar
Re: Cluster Swap
The 96-00 EX cluster will swap right into a 96-00 LX/DX with no mods. Just plug it in. But you have to swap a manual for manual and auto for auto.
Old May 7, 2008
mdawg's Avatar
mdawg is on a distinguished road
Re: Cluster Swap
I have already tryed putting a 03-05 cluster in my 97 civic. The gas gauge will be off, your tach and speedo will work along with your odometer. I could not get much more than a few warning lights on the cluster to work because they are simple not labled on the diagram I have nor could I figure out how to get the temp gauges working either. If you have a better layout of what the pins do then please feel free to post it, I ended up just pulling the cluster and giving up.
Old May 8, 2008
lobomic's Avatar
Re: Cluster Swap
alrite u said manual 4 manual, auto 4 auto with cluster swap. i didn't really think it would make a difference but i got my hands on a cluster from a manual. uhh why does this matter? if u don't mind me asking?
Old May 8, 2008
Re: Cluster Swap
maybe try it anyway. i know on the 01+ cars, you can use both, its just you will lose or gain the auto gear indicators. or they might work weird if you have manual and use auto cluster.
Old May 10, 2008
sql_civic's Avatar
Re: Cluster Swap
[QUOTE=gearbox;4314359]...its just you will lose or gain the auto gear indicators.QUOTE]
Exactly.
Old Aug 1, 2013
ahmad77084's Avatar
ahmad77084 is an unknown quantity at this point
Re: Cluster Swap
I have a 96 Honda Civic DX the cluster is working fine but I don't have rpm. So as you said the swap to ex cluster will be easy and useful?? THX
Old Aug 1, 2013
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
Re: Cluster Swap
Why not swap it for an lx one? Same engine code.
runawaykinms
15
Mar 22, 2019 10:32 AM
fatih717171
Jul 25, 2016 06:22 PM
wingsfan19
Oct 1, 2015 03:45 AM
DatGuy_Robb
Sep 3, 2015 08:08 AM
fatih717171
Jul 8, 2015 12:14 AM
