Dome lights
Old Feb 4, 2008
MetalcoreSlave's Avatar
MetalcoreSlave is an unknown quantity at this point
Dome lights
In my 97 Civic Ex, my dome lights refuse to come on when I open my doors.
I have to manually switch it to the "on" position, and they work fine.
Yes, I have tried it in the middle position too xD but they won't turn on for some reason.
What should I do/check?
Old Feb 4, 2008
Re: Dome lights
check the door trigger to see if the ground is still good. or it might be broken. should be a nipple looking thing near where the door closes against the car body
Old Feb 4, 2008
Re: Dome lights
Alright man, will do!
I'll let you know in the morning what I find.
It's freezing outside >_<
Old Feb 7, 2008
Re: Dome lights
So, I unscrewed the "nipple" and all I saw was some sort of plastic connector, and a green wire leading from it.
Where is the ground at?
Old Feb 7, 2008
Re: Dome lights
its grounded through the screw to the door frame. so make sure there is no rust or corrosion around that area. could be just a bad ground.
Old Feb 7, 2008
Re: Dome lights
I didn't see any rust or anything.
The switch pushes in just fine too.
Hmmm, is there anything else that could cause it?
Old Feb 7, 2008
thesob40's Avatar
thesob40 is an unknown quantity at this point
Re: Dome lights
If you replaced the stock head unit it disables the dome light when the doors open but the dome light will still work. Thats what happened with my 97 ex. I'm not 100% sure but i think the stock head unit controls all that stuff.
Old Feb 7, 2008
Re: Dome lights
Ahh! Why didn't I think of that X_X
Thanks man.
I'm guessing the only way to bypass this would be to mount my old headunit somewhere.
Old Feb 7, 2008
Re: Dome lights
yeah and the keyless entry if you have it. crazy why they did that for those year civic
Old Feb 7, 2008
-SIC CIVIC-'s Avatar
-SIC CIVIC- is an unknown quantity at this point
Re: Dome lights
My stock headunit is still mounted behind my center counsol for that reason.
Old Feb 8, 2008
Re: Dome lights
Well, how would I go about running both?
I know the connector that needs to be hooked to the stock unit, but do I need to get some juice to it too?
Old Feb 8, 2008
Re: Dome lights
well what i did with mine was run separate power and ground wires for the good deck. so that would be easy for your situation. just plug the harness to the stock radio and run your aftermarket with independent power and ground. i believe the factory deck just has to be getting power to activate the dome light and keyless. so you can just cut and splice the speaker wires to your new deck.
Old Jan 24, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Re: Dome lights
I think there's a Bypass Module but i'm not sure. Anyone?
Lopes101
Jun 7, 2015 08:04 PM
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
