starting problems
Old Jan 27, 2008
knil350's Avatar
knil350 is an unknown quantity at this point
starting problems
I installed a new head gasket in a 97 Civic SOHC VTEC because of low/no compression. Set timing up according to the book and it won't start unless the distributor is turned counterclockwise about 1/4 inch past the mounting holes. The crank sensor read 348.2 ohms and the limit is 350, but the others checked okay. once the car is started, you can turn the distributor back to the proper spot and it will idle, but not restart. No codes. Any suggestions?
Old Feb 15, 2008
sql_civic's Avatar
Re: starting problems
How do you know the proper spot for the distributor? Are you checking the timing with a timing light and the SRS connector jumped? Is your idle set properly?
Old Feb 18, 2008
RonJ's Avatar
RonJ will become famous soon enough
Check your timing belt. It may be off by one or two teeth.
CarStuff
Dec 6, 2020 12:52 PM
black2k1vtec
Dec 6, 2001 09:49 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
