96 civic idle fluctuation
Old Dec 18, 2007
nevillepa's Avatar
nevillepa is an unknown quantity at this point
I have 96 Civic si D16Y8 that I recently removed to rebuilt the head along with other work. I installed it and now after warming up for 5 minutes it the alternates from 1000rpm to 2000 in rhythm but idles normally when out of park. I cleaned out the ICV with no results, any help is appreciated, thanks.
Old Dec 18, 2007
sql_civic's Avatar
Re: 96 civic idle fluctuation
Did you mix up the plugs between the IACV and TPS? (or was it the IACV and the MAP sensor?) Check that the IACV, TPS, and MAP sensor are plugged into the correct harness plugs.
Another possibility is that you have a vacuum leak.
Old Dec 18, 2007
is it OBD equipped? if so, may need to do idle learn. drive car to warm up, turn off, disconnect battery, put back, start car, let idle 10 mins without pressing gas or using any accessory, turn off. start it up and see if it fixes idle.
Old Dec 18, 2007
nevillepa's Avatar
Thanks for the ideas, i am going to check them out.
Old Dec 19, 2007
TRIZ's Avatar
Please dont double post. Your other thread has been deleted after I moved the posts over. Thanks.
Old Jan 3, 2008
Sady's Avatar
Sady is an unknown quantity at this point
I know its an old thread but....you still having the problem? First off, reset the ECU like mentioned above. With 6th Gen Civic, the ECU doesent need to do a "idle relearn". Since you said you rebuild the head, did you make sure to scrape off ALL of the old intake manifold gasket? If you left even a little bit on, you'll have a vacuum leak, which will cause a surge in the idle. 2nd, make sure you have all the sensors plugged in to the right one. The MAP sensor and TPS sensor have identicle plugs. If you get them backwards, it'll cauuse the idle problem (thats even if the car runs. Sometimes the car wont even start/run w/the plugs backwards). Try those few things, and see what happens.
Old Feb 5, 2008
YooMisiek's Avatar
YooMisiek is an unknown quantity at this point
Hello. I'm Mateusz , I'm from Poland and I have a question , can't you help Me sending a feew part to poland , in Poland is very expensif and I come to you . I have a Honda Civic EJ9 1996 year and I love tune , please help me .
Bye.
mikemc422
Aug 9, 2018 05:41 PM
Fastfebur
Apr 26, 2015 11:57 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
civic_gt
Apr 19, 2015 08:15 AM
