D16 turbo build need advice
Rep Power: 0 D16 turbo build need advice
Im getting a d16y7 with about 100k on it gonna use this as my project motor im gonna build it from the ground up. It could possibly have a spun rod bearing. I want to turbo it. Now do i need to replace the crankshaft to run boost or will a stock crank work fine if so what aftermarket cranks do you guys recommend
Technical Assistant
Rep Power: 242 Re: D16 turbo build need advice
Crank will work just fine if you were building a race motor it would be zero balanced. Il talk to you about this in a few minutes when you come down here (if you dont get lost). With the spun rod bearing, since youll be building internals anyway, you can replace it easy.
Technical Assistant
Well I forgot so let me list it here, what is recomended...since you are gona have the motor apart anyway, build it. Im talkin forged pistons and rods (pistons for decompression), a new headgasket, ARP headstuds. All of the safety stuff now out of the way, look for a turbo setup. t3 turbos are a favorite. they are externally gated, and a fair size so you get quick spool, good power, and room to advance..dont get a t3/t4 its gona be too big. you will also need injectors, a manifold, blowoff valve, oil lines (tap oil pan for this). you will be able to run like 10-12psi with that, which will be good for 200+whp, and believe me itl feel like a lot coming from a DX hatch with an intake. I can go on and on about this stuff, but it can be had for very cheap. shoot me an IM when you get this nad we can discuss more
I could have given you the turbo in my garage, but with the state its in, if you tried to run it on a setup, it would probbably do more harm than good, its just a decoration now lol
Jaryn
05-17-2016 02:52 AM
bhollie
08-12-2015 09:58 PM
