increase performance
Old Sep 12, 2007
lynn's Avatar
lynn is an unknown quantity at this point
hi, currently thinking of doing one of these but need some opinions from you guys. feel free to comment.
1. high cam
2. P&P
3. hgih compression piston
wanna concentrate on low RPM coz low RPM is not very responsive now. thanks!
Old Sep 16, 2007
sql_civic's Avatar
Re: increase performance
lynn,
It would be helpful to know what specific model civic you have, what mods you've already done to it, and how many miles are on the engine.
However, if I was to improve low end response I would not do those mods. Maybe you should consider the following:
lightened flywheel
lightened crank pulley
Y8 transmission
increase displacement (bore and/or stroke)
B18 or B20 swap
Old Sep 17, 2007
TRIZ's Avatar
nitrous.
Old Sep 18, 2007
lynn's Avatar
Its ek 96 so4. Its about 164, 000 mileage. my service is due at 165, 000 so I'm thinking of doing the mod at one go. I havent done any major mods actually just a drop in air filter and a bullet.
I heard that crank pulley is bad for the gear box. Is it true?
Help much appreciated.
Thanks
Old Sep 18, 2007
lynn's Avatar
Oh and btw its auto transmission. =/
Old Sep 23, 2007
sql_civic's Avatar
An auto tranny (aka slush box), huh? Improving low end power in this case is not very promising in my opinion. It may not be what you want to hear but swap out the auto for a manual and you will get a big gain on the low end. It will also set you up for other mods that will improve that power band further. One option is to get the lightest rims for your tires that you can find.
The buzz on lightened crank pulleys is that they cause pre-mature bearing wear in the engine not the gear box. The reasoning behind it is that the OEM pulley has provisions built into it to absorb the harmonics of the crank shaft. Typically, the aftermarket pulleys don't have a harmonic dampener. Again, this is just forum buzz, many have installed these pulleys with no problems.
Old Oct 8, 2007
mugenpower89's Avatar
mugenpower89 can only hope to improve
Get another car with a standard gearbox..and then add a b16 dohc vtec and a set of cams intake and headers..get a proper exhaust too not a wal-mart fart can..or if u wanna keep that car and engine then ditch the fart-can they sound dumb on an auto or get a proper gearbox then cams and exhaust..
Bruce2
Sep 27, 2015 08:45 PM
MamaBear2015
Sep 27, 2015 06:31 PM
