Maintenance Required
Old Sep 11, 2007
Unidentified's Avatar
Unidentified is an unknown quantity at this point
Unhappy Maintenance Required
I just noticed this afternoon that the Maintenance Required indicator has gone from green to yellow. I'm pretty sure that it's been in this state for less than 48 hours.
The last servicing was ~2000 miles ago.
There are no other warning lights indicating a problem.
There is no knocking from the engine, and no loss of power.
There are no unusual smells in the passenger compartment.
Exhaust is nominal.
Anyone experience something like this?
Old Sep 12, 2007
-SIC CIVIC-'s Avatar
-SIC CIVIC- is an unknown quantity at this point
Re: Maintenance Required
There is a slot in your gauge cluster, insert your ing. key and that maint. req indicator should go off.
Old Sep 16, 2007
sql_civic's Avatar
The maintenance required indicator is just based on the odometer. Every 3500 miles it will go from green to yellow to red. After you've done the maintenance, you insert your key to reset it to green. It is not an indication that there's something wrong with your car.
Old Sep 18, 2007
BoneStOck_176's Avatar
BoneStOck_176 is an unknown quantity at this point
wow good *ish i learned suttin new...
Old Mar 20, 2008
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
The maintenance light is for oil changes. It goes from green to yellow/orange at 7000mi. then to red at 10000. To reset it insert your ignition key into the slot below the speedometer.
Old Mar 20, 2008
TheJGB3's Avatar
The maintenance light is for oil changes. It goes from green to yellow/orange at 7000mi. then to red at 10000. To reset it insert your ignition key into the slot below the speedometer. And do this every oil change.
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
WWJD
Sep 23, 2015 12:56 PM
