gear selector hard after ATF flush
Old Jul 18, 2007
takkar's Avatar
takkar is an unknown quantity at this point
Hello all,
I recently got my transmission fluid changed at a shop and since then, I am having problems to move the gear shifter from from P to R (all other gears changes work fine).
The other day, it went half way from R and P and stopped...had to put it back in in R and then into P.
Any ideas why this is happening?
Thanks in advance
Old Jul 18, 2007
takkar's Avatar
Re: gear selector hard after ATF flush
oh...forgot to add that I have a 1999 SE (which is a DX in the US [non VTEC version])
Old Jul 18, 2007
RHCP0801's Avatar
did you check how much fluid is in it?
Old Jul 27, 2007
sql_civic's Avatar
x2
See if the morons who changed the fluid didn't screw up the job.
Old Jul 27, 2007
ESK1k20A2's Avatar
ESK1k20A2 will become famous soon enough
u don`t have to change the fluid unless is black or seens burn
Get some lucas
Old Jul 28, 2007
ESK1k20A2's Avatar
did they flush the tranny ?
Old Mar 20, 2008
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
Honda recommends a "drain and fill" only on a tranny. There is a drain plug on the bottom of the tranny. Use a 3/8" ratchet to remove it. 2.5 to 3 qts will drain out. Put the plug back in, and add 2.5-3 qts with a funnel in the dipstck hole. Start the car and run through all of the gears. Then drain again. Reinstall the plug and refill again. Start the car and shift through all the gears. Drain it once more and refill. Now you will be good for another 100k. USE HONDA ATF-Z1 OEM FLUID ONLY!!! It does run $6/qt, but if you use anything else you will have nothing but problems.
Old Mar 20, 2008
maybe he used cheap fluid lol
fvckbg
Jul 7, 2015 07:08 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
markp94
Apr 30, 2015 09:19 PM
