Moonroof in a 97 LX?
Is there a decent way to have a moonroof installed in a 97 LX Sedan? Just throw me some numbers on how much one might charge for this and where it can be done. (Give me numbers for having it done completly vs. also If say I get parts for it from a junkyard first then have someone cut and do the labor) Thanks!
Re: Moonroof in a 97 LX?
get the parts and then get it done. Gotta go to a body shop and have them hack the roof and do the install, you'll need the sunroof headliner too. You could probably figure out the wiring.
I have no clue. if your able to get the entire roof from a car, it should be a little easier I would assume? Cut and weld essentially. Then you gotta get them to clean up the welds, sand it down, and get it painted. This way would be easier in the sence you have all of the attachment points on the roof allready. You know the sunroof has to slide to open (not sure if yours is inside the car, or on top of the roof), but the mounting points for the headliner, and there are a few simple brackets that the lights and junk screw into. Best bet would be to take your headliner off, and the headliner of a moon roof car like yours, and compare the inside roof to see what you'll need to change.
Removing my headliner is pretty easy (7th gen). Just pull the weather stripping off, unscrew all the lights (pry off the lense first with a razor blade), and pop the pillar panels off- the seat belt one as well- which requires a rachet for the seat belt bolt that was like 18mm or something.
well if ur gonna do an 'operation' like that make sure u go to well reputed PROs... i have several friends who get leaks in da rain and snow... so if u really need it jus make sure da people installing it do a good job so u dont have that problem
Dakota21601
Aug 18, 2015 08:41 PM
Ronin
44
May 9, 2003 03:04 PM
