5spd transmission rattle (like you guys havnt had to deal with this before)
Old May 11, 2007
Lonewolf317's Avatar
Lonewolf317 is an unknown quantity at this point
Exclamation 5spd transmission rattle (like you guys havnt had to deal with this before)
Hey
I just bought a 1999 Honda Civic Ex, 4 door, 5spd, and when I let up off the clutch in second, third, and fourth, it it makes a type of rattling noise, or the type of noise you would hear if you put a piece of metal on another piece of metal and vibrated them. it is more noticeable in these gears and not so much in 1st or 5th. I hate to bring this issue up if it already has been posted, but I have been looking for about 1 hour now on these forums, and cant find anything
Help is greatly apricated
Thanks Guys
Andy
Old May 14, 2007
-SIC CIVIC-'s Avatar
-SIC CIVIC- is an unknown quantity at this point
Re: 5spd transmission rattle (like you guys havnt had to deal with this before)
Does it have a aftermaret shift **** on it?
Old May 14, 2007
tmillard's Avatar
tmillard is an unknown quantity at this point
I have the same issue and was just about to write a post about the part names. My problem started with a stock shifter. It rattles in the car (the shifter) and under the car near the engine. It tends to do it at the same times you mentioned. I took it to my shop and had them take a peek at it. They said it is the 'shift rod and bushings', and said $300 to fix.
This weekend I was under my car installing a short throw shifter so I took a look at what they were talking about. The rod that connects the shifter to the transmission has some play at the transmission end of it. This I believe then wiggles due to engine vibration and because of the leverage follows through into the interior via the shifter.
So I hope that answered the question of what it can be.
WHAT I NEED IS:
What is that rods name and what are the bushings names? I figure I can do it myself and save $200 or so from the shop. Anyone know? When I look up 'shift rod' I tend to bring up the shifters. I think it might be called a 'countershaft' but I can't seem to find any for sale. Let me know if you know what it is called or where I can buy one. Thank you.
Old May 14, 2007
ukkev2000's Avatar
ukkev2000 is an unknown quantity at this point
Originally Posted by Lonewolf317
..when I let up off the clutch in second, third, and fourth, it it makes a type of rattling noise, or the type of noise you would hear if you put a piece of metal on another piece of metal and vibrated them. it is more noticeable in these gears and not so much in 1st or 5th.
Sounds like my problem - 5sp 1997 civic, when in neutral with no pedlas depressed, it would sound like something metallic was scraping round in the gearbox.
Depress the clutch, the noise slowed until it stopped.
If I was free-wheeling down a hill with the clutch depressed, I still got the noise.
Problem was the gearbox mainshaft bearings. Easy to replace, just a long time to get to the box to work on it. Oh, Honda parts for the job came in at £130, in fact Honda quoted £570 for the job. I found a gearbox specialist locally who did it for £400.
An expensive time for my car - the thrust bearings went last year and now this.. hoping it's gonna be better behaved now.
Good luck with yours.
Old May 15, 2007
No it does not I want to find a short throw for it. once and a while it does not make the noise at all, and some times you can hear it in first if you are pushing the car. the only things on it that are after market are cold air intake and exhaust
Old May 20, 2007
Well The only things that any transmission shop are telling me is that the trowout bearing is going bad or the clutch plate is making the sound
Old Mar 20, 2008
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
It could also be the catalytic converter heatshield.
Old Mar 20, 2008
Nitro Express's Avatar
Nitro Express is an unknown quantity at this point
First thing I would check is if the linkage is coming in contact with the exhaust. I put a short shifter on my 2K EX and it did exactly the same thing, spaced my exhaust down about 3/4" and have no rattle. As I'm sure everyone knows, the short shifter extends the link arm below the pivot point so that the upper arm moves less but still maintains the same arc length below the pivot point.
Old Mar 21, 2008
sql_civic's Avatar
Prothane makes a polyuerathane bushing kit for the shift linkage that's not expensive and not hard to install. I would get under the car and start shaking the exhaust (when it's cold!) and linkage by hand to check the play on it.
You can also just get these parts from the dealer for relatively cheap.
I would get parts #11, 4, 16, and 14 and maybe others depending on the condition of the old parts.
Old Mar 27, 2008
highbars's Avatar
highbars is an unknown quantity at this point
My 99 Civic hatchback was doing the same thing. My mechanic said all of the bearings probably needed to be replaced in the tranny. This noise lasted for a month and all of a sudden my tranny seized up.
Old Mar 27, 2008
highbars's Avatar
My 99 Civic hatchback was doing the same thing. My mechanic said all of the bearings probably needed to be replaced in the tranny. This noise lasted for a month and all of a sudden my tranny seized up. By the way it has 508,000 miles on it and needed a rebuild anyway.
Old Jan 30, 2010
Grewe02's Avatar
Grewe02 is an unknown quantity at this point
Edit: I know this is 6th Gen forums, but I couldn't find anything in 7th Gen.
Recorded from the passenger floorboard of my '03 Honda Civic, 55k miles, 5 speed, 4 door LX ( I think. Its the one with the 1.7L )
http://www.youtube.com/watch?v=Q1YEALFG0wE
0:05 Reverse
0:15 1st at low RPMs
0:33 Uphill in 1st gear, acclerating to ~30 MPH and ~4.5k RPMs
0:48 Clutch pedal depressed, Neutral
0:49 Turn signal
0:54 1st gear
0:57 ~3k RPMs shift to 2nd and coast downhill
1:13 Clutch pedal depressed, Neutral
1:18 1st gear
1:21 2nd gear
1:25 3rd gear
1:31 4th gear, ~4k RPMs
1:37 3rd gear
1:40 2nd gear
1:47 1st gear
From what I've noticed, this noise only happens from 1st - 3rd gears at any RPMs. Above 40 MPH and below 3k RPMs I think road noise is louder and covers up any transmission noise.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
May 10, 2015 08:11 AM
BootyDo
May 8, 2015 05:36 PM
Rinzlor
Apr 24, 2015 10:33 AM
wsking77
Aug 29, 2001 05:34 PM
