Need some advice.
Old Jan 30, 2006
imported_TunerX's Avatar
imported_TunerX is an unknown quantity at this point
Need some advice.
I have a 2000 honda civic LX sedan, I know there isn't alot out there for my particular car but I've found some stuff online. My question is, if i'm planning to do any engine upgrades, what would benefit me the most. I already have an AEM cold air intake and by this summer i was planning on putting in a Magnaflow cat back exhaust and AEM cam gear and pulleys. Does this sound like the right way to go? Also if I don't have a turbo on my car, would changing the fuel rail and injectors benefit me at all? any feedback would be appreciated.
Old Feb 1, 2006
x-raysteve's Avatar
x-raysteve can only hope to improve
I do not think changing the injectors would do anything at all.
I suggest you look for a different car if you want my honest opinion!
Old Feb 1, 2006
imported_Sam's Avatar
imported_Sam is an unknown quantity at this point
Look for a different car? That's a strange suggestion.
A modified Civic will perform as well as a car three times its price.If you turbo the car, yes its advised to change the fuel system, this includes, pump, injectors, rail and fuel pressure regulator as you will be requiring more fuel when the car is putting out more power.
Old Feb 2, 2006
imported_raven's Avatar
imported_raven can only hope to improve
injectors
Replacing your injectors will give a slight horsepower boost, but what you'll save the most is your mpg. If you are still running with stock injectors, replacing them will help your engine work more efficiently, as well as save you a bit more money.
Old Feb 2, 2006
Tayler's Avatar
Tayler can only hope to improve
There is no need to get injectors yet, you do not have any mods that would need you too. It would actually hurt your gas mileage because the extra fuel is not necessary. Just get the basics, header, exhaust, maybe some cams and cam gears for now....
Old Feb 2, 2006
Tayler's Avatar
TunerX
Junior Member Join Date: Jan 2006
Quote:
Originally Posted by Tayler
What good would it do to get titanium valve train when it is completely not needed with his current mods? Intake and cams doesnt make a valvetrain neccesary..... I have alot alot more mods than that and i dont have them and my car runs very strong. The only reason he would need to get a valvetrain is if he got stage 3 cams......
TunerX's post
For somebody with a decade old car that's only putting 155 to the wheels I would'nt b giving too much advice.
Actually if i were you i wouldnt be giving any advice if you have to ask questions about a pretty much stock car and getting upgraded fuel injectors. hahaha
Old Feb 2, 2006
Originally Posted by TunerX
I already have an AEM cold air intake and by this summer i was planning on putting in a Magnaflow cat back exhaust and AEM cam gear and pulleys. .
If he plans to buy these, then an upgraded fuel injector will help his car perform better. The cold air intake will provide the engine with an increased amount of air, so upgraded fuel injectors would be beneficial to compensate for the increased air flow to the engine.
Old Feb 2, 2006
Tayler's Avatar
The gains are very very minumal. The money is better off being spent on other mods for right now. I have alot more dont than that and i dont have a upgraded fuel system and my car runs great. Im not saying it wont help but it is not neccesary and you will not get your moneys worth.
Old Feb 2, 2006
Tayler's Avatar
haha, ok, actually my parents only gave me 300 dollars combined with the two cars i owned, a 1992 Acura Integra and now my civic. Just because i know what im talkin about you dont have to be offended because a 17 year old knows more than you. I still have alot to learn, i know, but i dont talk about stuff i dont know anything about. What have i been wrong about??
Old Feb 2, 2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
Im not going to pick on you as you are learning (as I am as well anyway), but you said cam gears were a basic mod - they are far from it. No one updates cams and cam gears unless they have other extensive engine mods.
Old Feb 3, 2006
Tayler's Avatar
Thats the way i went and it worked fine for me, there isnt a whole lot of options for all motor. You have to start somewhere.
Old Feb 11, 2006
Albaniancivics's Avatar
Albaniancivics is an unknown quantity at this point
if u want a difference on your car get a competition clutch and a 8lb flywheel and change the ecu, i believe thats gonna make a big difference.
Old Feb 12, 2006
MeerKat's Avatar
MeerKat is an unknown quantity at this point
Is a new flywheel necessary unless you are making big power figures?
Wouldn't a lightened one be overboard otherwise?
Old Feb 17, 2006
eShutterBUG's Avatar
eShutterBUG is an unknown quantity at this point
To jump into the argument that took place a while ago... -- I agree about the fuel injectors, if he's installing AEM cold air intake and the others, you will need upgraded fuel injectors to match the air intake. That will help balance it out a bit.
Old Feb 17, 2006
i'M GETTING CONFLICTING STORIES HERE, BECAUSE THE GUYS AT 1320 PERFORMANCE HERE IN JERSEY TOLD ME UPGRADING THE INJECTORS WOULD JUST FLOOD THE ENGINE, AND THEY BUILD ENGINES.
Old Feb 17, 2006
Tayler's Avatar
Thats exactly what i said but i guess i dont know anything. Like i said in my previous post you do not need upgraded fuel injectors with just a cold air intake.......
Old Feb 17, 2006
GoneIn60's Avatar
GoneIn60 is an unknown quantity at this point
Also dont waste your money on little things such as the AEM underdrive pulley's. 1 you dont want to get them if you are running subs or anything heavily electrical in your car because they take power from your alternator. 2 I have them and i have noticed minimal to no difference at all and i dont think they are worth the 140 bucks or w/e they go for now.
Old Feb 18, 2006
Alright then,besides the fact that my engine is a piece of s... , and i'm not planning on doing a swap any time soon , what other options do i have. I know I can change the cam and the cam gear and I can definetly put a cat back exhaust. If I do the exhaust first and then decide to do a swap , i shouldn't have to change the exhaust again , should I?
Old Feb 19, 2006
Tayler's Avatar
You more than likely will have to get another exhaust if you plan on swapping. If you are thinking about swapping just save your money and wait because you wont get your money back on the parts you buy for the engine that is in your car now. If you dont care about that just get a header and exhaust.
Old Feb 19, 2006
sizzler's Avatar
sizzler is an unknown quantity at this point
If you get a good exhaust this time then you wont have a to get a new one if you do an engine swap.
You might have to change the headers to fit, but the rest of the exhaust will be fine if its a decent size.
Harding12390
Apr 6, 2018 11:43 AM
sf3r8z
Sep 23, 2015 03:26 PM
danace99
23
Jun 28, 2015 08:49 AM
crowtoo
May 11, 2015 06:50 PM
PiCASSO
Apr 6, 2002 12:18 AM
