Life expectancy on OEM rear struts?
I am Epic
Rep Power: 0 Life expectancy on OEM rear struts?
HI, is anyone still on the OEM rear struts? I know someone who is selling a brand new set of Kayaba rear struts for $200, retails $300. Im still using the oEM struts at 88,000 miles. When should we replace the rear struts? Also is Kayaba good for struts?
Rep Power: 787 Re: Life expectancy on OEM rear struts?
the stock stuff wont last more than 50k miles. usually much less esp the rears.
I am Epic
Rep Power: 0 Re: Life expectancy on OEM rear struts?
So is Kayabas good? I have all this rattling from the back of my car so im guessing maybe replacing the struts will get rid of it.
Oh and crap i see i have to get a 4 wheel alignment if i change the struts out. I just got one done crap!
Live for the Twisties
Rep Power: 260 Re: Life expectancy on OEM rear struts?
It's all about driving style and conditions, they could last that long they just usually won't.
Order KYB GR-2 replacements for all four corners, it should come out to less than $300 online.
I am Epic
I googled Kayaba made in japan struts and it looks like kayaba and KYB are the same make. My front are only 2 months old, theyre Zoro brand made in japan too.
+2 on the 50k mile average.
Fronts carry more weight, but they're designed to do that and they only wear out faster because people abuse them.
you should have the same struts on all four corners and you should replace your shocks, the rattling is there because your way over the appropriate mileage for changing them, that's our advice but the final decision is all yours.
I am Epic
I asked some other civic owners and from what ive been told our cars only have struts in the front, shocks are in the rear and theyre a lot easier and quicker to replace than struts they said and that i wont nessecarily need a 4 wheel alignment after.
How many struts and shocks are on my car? I thought struts and shocks are the same.
You have struts up front and shocks in the rear, the difference is between the two is negligable in this discussion.
I am Epic
Thanks for clearing that up, I was getting really confused because I thought it was 4 struts and 4 shocks on our cars. I picked up the shocks just now from the guy and it turns out to be KYB GR2s!!!! When I install these tommorow, you think the noise from the rear will forsure be gone? Its not the swaybar end links making the noise?
Sway bar endlinks and blown struts make a similar rattle, so its hard to say. Have you noticed a drop in ride height in the rear?
If it is the sway bar endlinks you can remove the sway bar until you get a set of replacement endlinks, you'll just have a little more body roll when turning.
I am Epic
Im guessing i should definitely replace the OEM springs huh?
I am Epic
Rep Power: 210 Re: Life expectancy on OEM rear struts?
This is for a 2003. If #'s 1, 2, 8, 9, 10, 11, 12, 13, 14, 15, or 16 are worn then replace them: http://www.hondapartscheap.com/south...t=0&quantity=0
I am Epic
Do most people generally replace the springs too while doing the shocks?
Received 1,442 Likes
Rep Power: 338 Re: Life expectancy on OEM rear struts?
GOD... READ BEFORE POSTING is a good advice. As Lazlong said from start, replace if BAD, not replace them. Springs do normally last a loooong time, why you asking if need replace? any trouble with them?
searching does take you a long way.
My rear shocks on 2001 Lx were even still good last month when i replaced them. I replaced them as i had them from a year ago when i bought a set of four. My front ones failed at 125000. I replaced rear ones at 142000 . they were still not making an noise but i noticed an elevated height afterwards. As mentioned, it all depends on weight carried in rear and road conditions that put rear shocks to work.
Let us know, if replacement fixes that rattling.
I am Epic
So I got my KYB GR2s put in yesterday and the rattling is still there but its a different rattling now, more like a minor small pop sound here and there. Its sttill coming from the back right tire. Its on and off so not happening all the time. Mostly get it when turning left and some bumps. Checked the sway bar end links and they were fine, just the right 2 bolts were rusted but not worn out or anything. I know new shocks have to seat themselves first but how long does that take?
Do you think this could be the body panel making the noise? Because body panel rattling sound likes very close to it.
Have your buddy push down on that corner and listen for the pop. I bet one or more of the bushings is shot. Also check the swaybar bushings.
I am Epic
Im really believing that it is my body panels because when i put my car in park into drive and so fourth i hear the exact same creaky sounds from the back. I get it too sometimes when i release my ebrake'
plastikman
16
05-19-2005 05:53 AM
