eBay Coilover installation
Rep Power: 0 eBay Coilover installation
I just got my ebay coilovers from dna motorsports for my 2001 ex coupe.
are they easy to install?
does anyone have any intructions they can share with me or any tips. I appreciate it thanks
Received 1,149 Likes
Rep Power: 485 Re: eBay Coilover installation
look up the spring install DIY. It's the same process. Easy to do. Prolly take you a few hours.
However, I don't know if I'd trust ebay coilovers... But that's just me.
https://www.civicforums.com/forums/4...info-pics.html
Rep Power: 232 Re: eBay Coilover installation
i suggests you return them immediately ebay products are cheap and unreliable some are downright dangerous . also the ride quality will be awful. send them back.
Live for the Twisties
Rep Power: 260 Re: eBay Coilover installation
Ebay is good for little things like intakes and strut bars, because if they break nothing bad will happen. Suspension and brakes aren't something you can afford to take risks like that with, because a failure while driving would be catastrophic.
There's a reason why Ground Control coil overs are $400 and ebay ones are $75, the ebay ones probably have a higher profit margin too.
Received 1,443 Likes
Rep Power: 338 Re: eBay Coilover installation
actually the OBX coilover kit for miatas are very good and many uses then for track as well.
just depends on luck to get a vendor that have more reliable parts. and you need to try to find the ones that work or are safe, but this endeavour could end costing a lot in the end after trying several of them... worth? sometimes not. matter of luck? yes.
bottom line? if you don't know and you don't want to have one of the pieces that connects you to the ground (tires, suspension, brakes), and you don't have the ***** to try, just don't cheap out.
Rep Power: 0 Re: eBay Coilover installation
Well in the end .. I had to take my car to a shop.. had to get a new front axle.. broken CV joint.. and major slamming on the drivers side.. bill was 748$ .. NEVER BUY EBAY COILOVERS
1 Post
Rep Power: 328 Re: eBay Coilover installation
on a side note, this thread is full of win.
mjdiaz89
06-21-2016 09:26 PM
Bill in San Jos
07-10-2015 12:32 PM
fvckbg
07-07-2015 07:08 PM
