2005 civic oil question
Rep Power: 0 2005 civic oil question
I have a 2005 civic with 55k miles on it. I've used 5w 20 oil as indicated by Honda when I first bought the car (with 11k miles). I noticed back then the transmission used to **** harder and sometimes the engined idled when changing gears. I started using 10w30 oil and the problem stopped. I recently went back to 5w20 synthetic oil, after reading countless articles on sticking with the manufacturer's suggestion on oil types. After l changed it back to 5w20, I noticed the same issue as before. Is this a common issue? What type of oil to you guys use on your 7th gen civics?
thanks
thanks
Rep Power: 788 Re: 2005 civic oil question
i switched to 5w30 after the engine got over 60k miles. it wears in and tolerances get looser, so you really need a thicker oil. 5w20 is just too thin if you live in warm climate.
LionSpratt
01-29-2017 11:07 PM
civic_gt
04-19-2015 08:15 AM
twtron
04-17-2015 12:09 AM
