04 engine swap
Old Oct 30, 2018
3can's Avatar
3can is an unknown quantity at this point
04 engine swap
I have an o4 civic with a bad engine... I pulled it out picked up another engine and when I went to set it in noticed it had a solenoid on the intake side of the head that I guess is called a vtec solenoid??... the original engine does not....if I put the new engine in without hooking up the 2 plugs will it hurt anything??... my car does not have the wiring for the 2 plugs...
Original engine
New engine
Old Oct 30, 2018
Re: 04 engine swap
It will run without that solenoid connected to anything.....
some people would give their left one to have that engine, maybe it's hard to find in some areas
Old Oct 30, 2018
3can's Avatar
Re: 04 engine swap
More so worried about the oiling aspect of it cause if I take that solenoid off there are oil passages behind it and someone told me it wont have the right oil pressure and will burn up if I run it without it hooked up....
Old Oct 30, 2018
Re: 04 engine swap
That person does not understand how the system works.
The VTEC valve does not control lubrication at all.
It controls a hydraulic actuation system that uses engine oil pressure as its hydraulic fluid.
In a car that is set up to use it, it is not even activated until high RPM so it spends most of its life not turned on anyway (for average drivers).
Leave the solenoid in place, the engine will run fine without it connected to anything. You might want a fresh gasket for it though since you disturbed it.
Old Oct 30, 2018
3can's Avatar
Re: 04 engine swap
Ok that's kinda what I thought but after hearing from him I was kinda concerned lol
Mosn Jadoon
Engine Swaps
Nov 30, 2017 01:00 PM
Dabtron
SOHC D17Ax non-VTEC - VTEC Engine Swaps
26
Sep 6, 2017 10:39 PM
crytikall
Jun 4, 2011 08:29 PM
d-ram-man
Jun 3, 2011 02:34 AM
brokemycivic
Nov 2, 2008 08:55 PM
