P0128 Code
Old Oct 28, 2018
caribu's Avatar
caribu is an unknown quantity at this point
P0128 Code
I have a 2003 Civic with 195K miles, I started getting the P0128 code. I replaced the thermostat with a Honda OEM thermo, and now I am still getting it. All coolant levels look OK and I am using 50/50 blue antifreeze. Also just had the radiator replaced a few months ago, but code just started a few days ago, not sure if anything is related. Here is some of the freeze frame data from the code, not sure if this helps but maybe somebody knows. Any ideas what else this could be?
LOAD_PCT(%)=88.2
ECT = 86F
SHRTFT1(%)=0.0
LONGFT1(%)=5.5
MAP(psi)=13.1
RPM=2715
VSS(mph)=23
IAT=57F
TP(%)=32.9
Thanks!
Old Oct 28, 2018
Re: P0128 Code
ECT = 86F
I'd probably want to check if this sensor is actually accurate. You sure that wasn't 86*C instead of F?
P0128 sets when the computer thinks it's taken too long to reach operating temperature. Typically that happens when the thermostat sticks open (or similar fault), but what if this ECT sensor isn't accurate? What do you think the computer might do?
Old Oct 29, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: P0128 Code
Do you have other DTC codes other than P0128?
Since you had the radiator replaced recently, I would check for poor or loose connections at the radiator fan sensor and the PCM. Also check the radiator fan circuit, the radiator fan switch circuit and the radiator fan switch. You already covered the thermostat with the replacement OEM Honda thermostat.
Finally could be a faulty PCM.
Hayden_Fourroux
May 16, 2020 03:35 PM
Joelship
Feb 11, 2016 09:23 PM
weasel_18
Nov 12, 2013 08:41 PM
Westley
Dec 18, 2012 10:55 PM
Tinkerbell_too
Dec 24, 2010 12:48 PM
