Sponsored by:
Sponsored by: DashLynx
Driving Lights switch to LED
Old 09-22-2018
Nadir2005's Avatar
Nadir2005 is an unknown quantity at this point
Hello people,
recently I switched my halogen day driving light to LED.
the passenger side lights worked, however the driver side did not.
i searches out possible issues online but I can’t seem to figure it out.
the LED light I am using in the driver side works, I tried the passenger side, so ruled out the defective bulb, I also checked the fuses, DRL relay and the DRL modul, nothing seems to be wrong. I put back the original bulbs and still not working. All the lights were operational prior to the switch, I attempted to buy a wire harness for the driver side, attached, but have not installed it yet. Has anyone experienced this issue and if you have any suggestions ?
Nadir2005 is offline
Old 09-22-2018
Slumpertcivic's Avatar
Re: Driving Lights switch to LED
If you didn’t use a current limiting resistor with your LED bulbs you might have fried your DLR module.
Slumpertcivic is offline
Old 09-22-2018
Nadir2005's Avatar
Thanks for the response .. I actually did some research on that very point.. all it said if that was the case to simply re-solder the back .. which I did.. still no go.. also on that point if it was fried would it not impact both driving lights?
SoundCivic
General 8th & 9th Gen
01-17-2019 12:20 PM
tintin20
09-28-2016 01:20 PM
zan118
12-02-2011 05:29 PM
irontodd
Lighting
01-10-2009 03:27 PM
TeLLy
06-14-2004 08:23 PM
Quick Reply: Driving Lights switch to LED
