Connected CD-C aux cable is acting very strangely
Old Sep 7, 2018
Auxhead's Avatar
Auxhead is an unknown quantity at this point
Hi there,
So I recently installed an aux cable in my honda civic 2003 LX it worked great at first until i drove around for around 10 minutes, then suddenly the music went extremely quiet. Now no matter what i do i cant hear the music unless its full blast and even then its extremely quiet. The very strange thing about all of this is that if do anything that requires power for example power windows or using turning signals or turning the headlights on or off it makes the music blast for a moment. Is this an alternator problem or a wiring thing? Or maybe a problem with a fuse? I dont really know what is causing it because the aux was working and it actually still is but now it seems like the stock radio isnt receiving enough power or something to use the aux properly. Any help or suggestions will be appreciated. Thanks!
Old Sep 7, 2018
GolNat's Avatar
Prelude Owner
Re: Connected CD-C aux cable is acting very strangely
Does removing the AUX from the HU remove the issues (music blasting when headlights are turned on)?
Sounds like there is a short somewhere and a wiring problem would be my first guess as it worked prior to you messing with it.
Old Sep 7, 2018
Auxhead's Avatar
The only thing i did was plug the wiring harness for the aux into the stock radio so i didnt mess with any wiring. the radio and cd player work fine on the same unit but when i switch to CD-C it is quiet. it wasnt always like this tho which is why i am confused. Again if i do anything that requires power it like makes the aux get loud or whatever volume it is set to on the radio.
Myvu94
Electronics
Sep 14, 2022 10:30 AM
Dave1984
Jul 22, 2015 06:10 PM
llashtur
Mar 20, 2014 10:32 AM
ckjy2kusa
Sep 28, 2009 04:32 PM
zachpolo
Jan 27, 2007 03:41 PM
