no power for audio stereo???
Old Sep 17, 2009
ckjy2kusa's Avatar
ckjy2kusa is an unknown quantity at this point
Hi,
2002 honda civic LX 4 doors My Tape player and radio were working fine, but not now after trying to install cd/radio after market unit.
No power on my OEM tape/radio or the new cd/radio unit.
check all fuses are good.
Put back the original radio/tape unit back = no power.
What is going on here? please please help
Thanks a million
Old Sep 17, 2009
vsTerminus's Avatar
vsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond repute
Re: no power for audio stereo???
Well my first assumption is that you blew a fuse. You sure they are all good? Check the backup fuse under the hood as well.
Did you use a wiring harness like you're supposed to, or did you try to splice into the existing wiring?
Old Sep 17, 2009
lexxie's Avatar
lexxie is an unknown quantity at this point
Originally Posted by ckjy2kusa
Hi,
Thanks a million
Honestly, I had to same problem last week. I had to back track everything, but i eventually found out what I had done wrong.
Old Sep 17, 2009
ckjy2kusa's Avatar
What have you found, please share.
Thanks
Old Sep 17, 2009
ckjy2kusa's Avatar
Where is the back up fuse? under the hood in the fuse compartment?
I bought a harness from ebay and use that.
Thanks
Old Sep 18, 2009
ckjy2kusa's Avatar
Found the problem and fix
back up fuse under the hood were blown.
thank you very much for your hep vsTerminus
Old Sep 18, 2009
vsTerminus's Avatar
At some point everyone blows that backup fuse and it's never an obvious fix. Glad you got it worked out !
Old Sep 28, 2009
lexxie's Avatar
I thought my wiring was done incorrectly, but I found out I blew a fuse. damn those fusesssssssssssssssss
Old Sep 28, 2009
mgiangas1's Avatar
mgiangas1 can only hope to improve
get ohm meter check the yellow wire it 12v constant shuld get 12v even with power off to car keeps clock nd prersets on deck wont runwithout it had same type issue with my 05 lx
Old Sep 28, 2009
Excal's Avatar
blah™
Excal is an unknown quantity at this point
Why would you use an ohmmeter to check voltage? He figured it out anyways it was a fuse but please make sure you use the right terminology if you are gonna give advice. Putting an ohmmeter to check voltage is gonna do nothing but give him the wrong thing he is looking for (there are some very novice people that use this site you have to remember that when you give help).
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
robbie374
Jul 7, 2015 02:56 AM
