2002 civic - shift solenoid valve A and B replacement
Old Jul 7, 2018
DavidKing's Avatar
DavidKing is an unknown quantity at this point
Need to clean the filter screens on solenoid to resolve a shifting issue. Problem started after doing a drain and fill. I assume debris is clogging the filter screens.
Where is this located on a 2002 Honda civic
Please assist.
Old Jul 7, 2018
Slumpertcivic's Avatar
Re: 2002 civic - shift solenoid valve A and B replacement
Deep inside the tranny, pretty much complete disassembly required and might as well replace the clutch packs and install replacement filter that’s bigger while your in there.
Old Jul 7, 2018
DavidKing's Avatar
It's not inside the tranny. Rather it's mounted externally. Dealer gave a diagram but it's not clear.
After fluid change if shifting between certain gears is rough, then most probably it's a clogged filter screen on the shift solenoid valve. My issue is between 1st and 2nd gears.
Old Jul 7, 2018
DavidKing's Avatar
Found it.
it's located at bottom left side of transmission. There are three bolts, two of them can be accessed from under car, but third bolt to remove have to take out the the solenoid assembly in front (Solenoid Assembly, Linear - Honda (28250-PLX-305).
Part (shift solenoid valve A and B): Solenoid Assembly, Shift - Honda (28200-PLX-003)
Old Jul 10, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
But there is also an internal transmission filter that can clog with debris as well. If that happens, then you will need to open the transmission case to access and advice is to install the larger ATF filter in the 2004 and 2005 transmissions and rebuild the trans at same time.
Sea Bass
Mar 31, 2016 06:52 PM
shoveljoe
May 15, 2015 11:09 PM
honda200192
Apr 12, 2015 10:28 AM
MartinL
Aug 10, 2010 11:12 PM
Vz.tech
Mar 27, 2010 07:14 AM
