Metal line to clutch slave cylinder?
Old Jun 19, 2018
Inkubus's Avatar
Inkubus is an unknown quantity at this point
I can't find the answer to this.
I have an 02 Civic EX, standard trans. The line coming from the master cylinder is your standard rubber hose. But it doesn't go into the slave cylinder, it goes into a connector which a different metal line connects to, which then connects to the slave cylinder. And yet when I look online for new lines, I only find one, flexible, often braided line.
Where can I find the metal line, as this is the only part that is damaged? Or is it that any time someone replaces it, they instead do the entire line with one continuous, flexible line?
Last edited by Inkubus; Jun 19, 2018 at 06:09 PM. Reason: typed threaded when I meant braided
Old Jun 19, 2018
Colin42's Avatar
Re: Metal line to clutch slave cylinder?
You can get a new hard line from the Honda dealer or make one out of brake line (much cheaper)
Old Jun 20, 2018
BrotatoChip's Avatar
Super Moderator
I believe you're talking about part 15 in the picture. Actual part number is 46960-S5A-A03, I show a price of $52. Item 16 is part number 46961-S5A-A01, says $41. Item 19 is part 46970-S5A-013, $12.
Last edited by BrotatoChip; Jun 20, 2018 at 08:40 AM. Reason: Additional information
Old Jun 20, 2018
Inkubus's Avatar
Thanks guys. Brotato, it is part #19 that I was referring to.
Old Jun 20, 2018
Colin42's Avatar
Check the condition of 15 while you're in there. I know on my old car it was getting pretty crusty but then I wrote the car off so I didn't have to worry about changing it any more
Old Jun 20, 2018
Slumpertcivic's Avatar
When I replaced my clutch, the 15yr old fluid was exactly same color as milk chocolate..
I used full bottle new fluid get it flowing mostly clear again.
powman02
Sep 15, 2015 07:38 PM
alwaysloyal360
Nov 15, 2014 12:17 PM
bsmiley
Jun 14, 2014 10:46 PM
2K1Civic17"Gabe
Jul 15, 2005 10:57 PM
riceburnrex
Dec 14, 2004 02:11 PM
