honda civic 02 door actuator
Old Feb 19, 2017
gulzarh's Avatar
gulzarh will become famous soon enough
i have Honda civic 2002 dx sedan. his back door rear driver, doesn't pop-up when i press unlock button on driver side door. all three door pop up (lock and unlock) but this one doesn't at all. i thought it is actuator problem so i bought one but it did not work also it mean the problem is not with the actuator. i tried this new actuator with other door and it work well. what can be the problem?
Old Feb 19, 2017
Re: honda civic 02 door actuator
Wire broken in the harness between the body and the door?
Old Feb 19, 2017
gulzarh's Avatar
how should i know where it is broken?
Old Feb 19, 2017
Peel the rubber cover back and look, gently tug on each wire in the bundle see if any aren't attached
Old Feb 20, 2017
Daron Edwards's Avatar
Daron Edwards is an unknown quantity at this point
Can you tell me how to unscrew the top for the door lock actuator that goes up and down for when the door Is locked or unlocked ?
Old Feb 20, 2017
gulzarh's Avatar
i will get you back with the result in next few day when i will check it. thanks
Old Feb 20, 2017
gulzarh's Avatar
Watch this video
Old Feb 23, 2017
gulzarh's Avatar
i checked it and look fine everything, no wire seem to be damage.
Old Feb 23, 2017
If 3 power door locks work but one does not, and you have proven the electric lock motor is good, then it is a wiring problem..
The most likely place for a break is where the wires flex each time that door opens and closes.
I'd do continuity tests on that door harness.....I still think the break will be in the jamb area. Unplug the actuator, unplug the harness connector on the B pillar, and test to verify continuity of the two lock motor wires.
Old Feb 24, 2017
gulzarh's Avatar
i will do again, i also have mulitmeter, is it usefull in this case?
Old Feb 24, 2017
CraigW's Avatar
^^^For Ohms mostly..... the pulse would be very brief to measure voltage though.
