Where to attach chains on engine support bar..
Old Jun 13, 2016
Phillip Plypots's Avatar
Phillip Plypots is an unknown quantity at this point
I'm following Scooty's Input Shaft Bearing DIY https://www.civicforums.com/forums/1...t-bearing.html and I've run into a problem. I'm pulling the Transmission outta the top. I've completed all the steps up until removing the major bolts holding up the engine and transmission, but I need to know where to hook up and bolt the chains to the engine support bar, purchased from Harbor freight. In his DIY he used a jack and boards to support the engine, but I wanted to be a little more safe and I purchased the Engine support bar. http://www.harborfreight.com/1000-lb...bar-96524.html Where to hook it up is what I need to know.
If you reply, keep in mind that this DIY is my first major job so please be specific when describing where to hook up at.
Old Jun 14, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Where to attach chains on engine support bar..
There are some pictures on am auto to manual trans swap thread that has some pictures or the engine hoisted
i dont know if it helps because it is not to clear where it is being hung from exactly.
Found what you where looking for https://www.civicforums.com/forums/1...o-i-strap.html
This thread has pictures of the manual, hope it helps!
GolNat
Suspension DIY
May 12, 2022 06:49 AM
scooty
Transmission DIY
64
Jan 16, 2020 11:05 PM
boyd117
Feb 15, 2012 11:22 AM
Sinblesser
Aug 31, 2010 11:46 AM
Xboxman
Jan 12, 2004 09:02 PM
