Sponsored by:
Sponsored by: DashLynx
Who has the most miles on their 7th Gen Civic?
Old 12-17-2017
  #61
MarcOtt's Avatar
MarcOtt is an unknown quantity at this point
Re: Who has the most miles on their 7th Gen Civic?
2003 Civic EX Sedan with 266 K and runs well and returns high MPG. Beside regular brake/ tire/ timing belt/ water pump/ spark plugs/ valve lash, and fluid services, had to replace the head gasket at 230 K (not an uncommon problem with these D17A2 engines) and alternator at 220K. In addition to the head gasket change, head was warped and the EGR system baffle plate/ports at the intake manifold was near clogged. Be aware this would have triggered a engine code if it was allowed to clog.
Recently replaced front struts due to strut mount bearing corrosion and radiator (weeping at lower plastic housing/core seal). Original automatic transmission, replaced fluid every 40 K and last 120K miles been using CASTROL Transmax AF fluid for Imports, and very pleased with the performance. Honda Auto transmissions won't fail with anything but Honda Z1 or DW1.
MarcOtt is offline
Old 07-09-2018
  #62
civicloco's Avatar
civicloco is an unknown quantity at this point
2005 civic LX 304K 5 speed original clutch.
civicloco is offline
Old 07-09-2018
  #63
GentleBen's Avatar
GentleBen is an unknown quantity at this point
Very good. Must have been mostly highway miles?
GentleBen is offline
Old 07-14-2018
  #64
s2kdemon's Avatar
s2kdemon is an unknown quantity at this point
190k. engine spun a bearing about a month after i got the car 5 1/2 years ago, so that got replaced. tranny wouldnt stay in 5th earlier this year so i replaced that too...
s2kdemon is offline
11-21-2017 06:26 PM
ANiceGuy
06-02-2017 08:24 PM
NFrances
16
07-03-2016 12:49 PM
Minntana
General 7th Gen
06-17-2016 05:40 PM
Section250
27
10-11-2012 01:22 PM
Quick Reply: Who has the most miles on their 7th Gen Civic?
