03 civic ex overheating
I have a 03 civic ex, replaced head gasket twice, and water pump, and new radiator, it still continues to overheat even idling sitting in my yard. the car did run for 5 months with the timing off 2 teeth. idk what could be tha problem, I have replaced the whole coolant system in my car and it still continues to over heat. please help!!
Re: 03 civic ex overheating
Changing a head gasket doesn't do much good if the head isn't perfectly flat....it will leak again.
And if it overheats bad enough, it can blow the head gasket and warp the head all over again, no matter how recently it was just done.
The PCM can also control fan operation when the HVAC system requests compressor and fans to come on, or the coolant temperature switch can operate the fans independently of the PCM when that temp switch is triggered.
So I'd probably unplug that switch and use a paper clip to jump the wiring connector (key ON) and make sure the fans can run if the temp switch closes its contacts.
Temp gauge high?
Blowing antifreeze out on the ground?
Smoke?
What do YOU see?
Is the radiator completely full?
Will it still overheat if you keep the fans running?(AC on)
I think the question should be, was the head inspected and measured and did it need to be resurfaced or did it measure within specs for flatness?
well my head didn't look badly damaged at all from how many times I overheated, everything looked fine, and I did it at my uncles garage, hea a master mechanic, he watched over me. when I did the gasket and belts, but accidentally my timing was off 2 teeth, so I couldn't Rev past 3500rpms, even while driving, I fixed that problem, and then my ecm started blowing, I blew 2 on my 3rd right now, and it's just been sitting in my yard, and I could never get rid if the over heating problem.
There's only one fan switch, in the thermostat housing.
I'll try that dude.
What makes you say it overheats?
Temp gauge high?
Smoke?
[U]What do you see?
well it was idling fine, maintaining perfect temperature, but the top coolant hose, was slowly getting hotter, and I kept peeking at my temp gauge, and it was holding in the middle, then started slowly rising up, and my coolant reservoir tank was steaming like crazy, so was my radiator.
I just replaced my new radiator, filled it up with antifreeze and water, cause it was concentrated.
I'll try that dude.
Temp gauge high?
Smoke?
[U]What do you see?
yes, with my backup coolant tank full too
Allright then, now I got several questions, see if you can answer all of them
1) Is the gauge telling the truth?
While it's showing HOT.......wrap your hand around the top radiator hose and see if it burns the crap out of your hand. If you can hang on to the radiator hose without pain, then your temp gauge may be lying about the temp.
2) when it's showing hot and the fans are running, are the fans blowing HOT air?
If the gauge shows overheat, then the fans should be pulling 200 degree air off of the radiator. (If you have the AC running to keep the fans on, it produces some heat of its own so it may be hard to tell)
You should be able to feel the radiator hoses and tell if top and bottom radiator hoses are screaming hot.
3) When it's showing hot--turn the heater on full blast and see if
a) the heater is blowing super hot air, and
b) if using the heater will bring the temp gauge down to normal (or down any amount)
4) How much time does it take to go from a cold engine to showing overheat on the gauge?
5) Have you replaced the thermostat yet?
Rob02Civic
Sep 16, 2018 09:16 PM
jdawgzcivic
Jun 30, 2015 06:35 PM
silentz
Jun 17, 2015 10:21 PM
si_me_now
Jun 3, 2015 09:19 PM
