Tire Plug Or Replace?
Old Aug 12, 2015
mikey1's Avatar
i have plugged a few tires in my time with good success, they have lasted for many years without any problems,
i have had a very slow leak in one of my tires for about 6 months now, i finally took it off today and found a nail in it
just wondering if its safe to plug this because the position is very close to the sidewall, its on the inside of the rear tire,
the tire is in good shape and less then a year old
i have attached a pic and circled it in red,
i am almost tempted to just leave it as it is, it only leaks about 4 pounds every 3-4 weeks, but the OCD side in me says i should fix it
Old Aug 12, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Tire Plug Or Replace?
For my own car I would plug it.
For a customer car I would replace it.
We have an old ramcharger at work used as a snow plow. It doesn't get many miles at speed, but last winter I noticed someone had actually plugged the middle of a front tires sidewall. It doesn't leak, likely wouldn't get thrown out at highway speed since the force would be against the side of the plug. But it does look spooky
Old Aug 12, 2015
Patch it from the inside?
Old Aug 13, 2015
CraigW's Avatar
^^^ That close to edge, I'd be afraid it would come off.
Old Aug 13, 2015
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
A third option if the puncture is in a place that can not be plugged is to put a tube in the tire.
Old Aug 13, 2015
Mikey, where were you? Hotter places have more issues.
It's not too recommend ed when it's too close to the shoulder of the tire. Yeah, the inner patch might be safer. You might need huge balancing weights to compensate, though.
Old Aug 14, 2015
mikey1's Avatar
thanks for the replies,
i am going an a 400 mile round trip this weekend and didnt have the time to repair or change it so im hoping for the best,
its been this way for 6 months so im hoping a few more miles wont hurt, i will deal with it when i get home,
i am in canada, so we get a wide variety of temps, right now its about 90F on a regular basis, but winter can get down to -40F or lower,
Old Aug 14, 2015
lowlife9's Avatar
its closer to the sidewall yes but its still in the tread patch it.
Old Aug 14, 2015
Lowlife, there's a rule that you don't plug too close to the outer shoulder. now a patch might be acceptable.
About experience: in one of my business trips that i have to drive a rental, i got a screw in the rear tire.
Thing is, it would loose 6-8 lbs in a night. but while driving, it would keep the pressure. it would leak only while parked.
i could get back (yeah, same 400 miles) and had to just fill it in the mornings and after work was done, going back to the hotel. No fill required during the trip.
then, again yours are leaking less, so should be OK for the trip.
Old Aug 14, 2015
The rule of thumb we use at work is one inch from the edge of the tread.
Old Aug 16, 2015
mikey1's Avatar
does this rule change, or does it make it more acceptable if its on the inside of the tire tread (which this one is)?
im back from my trip, no issues, like i said it only leaks about 4 pounds a month
Old Aug 16, 2015
The rule is there because of how much flex there is in that area of the tire -- 'radial squat' causes a lot of flex as the tire rolls with weight on it. Flexing can allow a repair to fail.
http://www.rma.org/wp-content/uploads/prp_wallchart1111.pdf
Disclaimer:
Of course you should check what the manufacturer of your tire brand has to say regarding repairs (website?), and if you decide to perform any repair outside the published guidelines you accept all responsibility for consequences of your actions.
Note: Disclaimers absolve the manufacturers for improper repairs.
You are free to do as you wish regarding repairs, as it is your car, your tire, and your bla bla bla ....
Reality: If it were on my car I'd plug it, or use a patch-plug, and see how long it lasts. If I get more service life out of the tire this way, I win LOL
I don't want to buy another $50-$200 tire if I don't have to.
CSB:
I had my roof redone (tear off and reshingled) several years ago, the crew did not do a great job cleaning up all the nails.
I was driving my truck daily at the time.....I pulled out of the driveway once and hear a "slap slap slap" as I roll down the street, I get out and look and find a 5" square chunk of shingle nailed to my tire.
Over the following couple months I put so many plugs in my tires it wasn't even funny. Worst was about a dozen different holes in one tire.
The plugs would dry out and leak after a few years, so they would get pushed in and a new plug installed.
I rolled on those tires....longer than any tire should be driven. The roof was done in 1995, and I just replaced the last of those tires last year.
Old Aug 16, 2015
mikey1's Avatar
yeah im thinking the same, i will plug it tomorrow, and make sure i always keep that tire on the rear, never on the front
Old Aug 18, 2015
OptimisticWay's Avatar
OptimisticWay is an unknown quantity at this point
I also use plug patches and have had great success with them for about 20 years. Tires are tough. I have plugged sidewalls successfully and never had an issue with plug/patch kits.
If a tire has a patch in an area inside the tire that arcs on the sidewall, YOU SHOULD NEVER REPAIR IT! It is not safe and if you kill someone and they can prove you performed this unsafe method, be prepared to be sued civilly and possibly face some prison time. That's pound you in the *** prison time.
On a car that only sees in town traffic no faster than 45 mph the risk is low for an accident it the tire goes bad. If you are going on the highway at 65 mph plus, I would put the tire on the driver's side rear so you can check it every time you get back into the car. If it blows out on the rear you still have your steering tires fully inflated and possess more control over the vehicle. Also, invest in some valve stem caps that have a red ring exposed when it drops below 32 or 36 psi. I have the 36 psi one that I use on trips. I bought mine from Wal-Mart for like 5 bucks. Lastly, find a 1 inch or 1½ inch plug/patch that may likely patch your tire safely and legally for you. Good luck.
Old Aug 19, 2015
mac25's Avatar
Dr Krieger of Modification
Industry standard is to replace... but that is because the average person will not check their tire pressures, which will lead to an under inflated tire, which will then have a folded side wall which leads to friction an a blow out.
Structurally there is no reason side wall damage (repairable sizes of course) will cause the tire to fail, if the tire will hold air.
It is the flex in the sidewall which can cause plugs to loose air which is the issue.
You could plug it then keep a tire gauge on you for a month.
Old Aug 19, 2015
mikey1's Avatar
thanks for the tips,
im a very OCD type person in every aspect of my life, and that relates to my cars as well, so needless to say i check my tire pressures at least once a week
Old Aug 19, 2015
lowlife9's Avatar
i know its taboo but my last set of tires had multiple plugs in multiple tires and im still alive to tell the tale. or maybe this is the ghost of lowlife9 speaking from the grave booooooooooo i need brains brainssssss.
Old Aug 19, 2015
Plugs are dangerous!!!
Leave the nail in the tread, that's the safest thing you can do.
It's even plugging up the hole in the tire so it doesn't leak air out so fast!
Old Aug 20, 2015
mikey1's Avatar
i was seriously considering this, seeing as its probably been like that for about 6 months, cause thats about how long ago i noticed it slowly leaking, but my OCD side in me is telling me to fix it
Old Aug 22, 2015
lowlife9's Avatar
ive been using plugs my entire life with no problems but i know there designed for temporary use only.
Old Aug 27, 2015
marteam's Avatar
marteam is an unknown quantity at this point
I would plug and patch it from the inside, then check the tire pressure on a regular basis.
Old Aug 27, 2015
mikey1's Avatar
i just went the plug route,
i has been about 4 days now and zero pressure loss
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
thesushiboy
Apr 12, 2015 02:54 AM
technosilver
Nov 14, 2001 10:58 AM
