Buying a 7th gen Questions
Old Jul 16, 2015
srtlat's Avatar
srtlat is an unknown quantity at this point
Getting ready to buy a 7th gen. Found one with some hail damage.
What should I look out for???
currently has 135k. Asking 4,000, manual transmission
Items done at 100k
timing belt
water pump
pads and rotors
plugs
fluids flushed
brand new tires
thanks
Old Jul 16, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: Buying a 7th gen Questions
Check the compression. 4k seams too much
Items done at 100k
timing belt
water pump
pads and rotors
plugs
fluids flushed
brand new tires
thanks
Old Jul 16, 2015
mikey1's Avatar
Items done at 100k
timing belt
water pump
pads and rotors
plugs
fluids flushed
brand new tires
thanks
if all this is true, it seems like its well taken care of
Old Jul 17, 2015
cja3455's Avatar
cja3455 is an unknown quantity at this point
check if the transmission is noisy when ideling by engaging the clutch and hearing if the car sound change
Drive it at high rpm for 10 minutes or so and check if the coolant overflow tank became full
Check for any oil leaks, cracked compliance bushings and any play in the wheels
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Hiryuu
Jun 6, 2015 03:00 PM
Lt. Dan
May 13, 2015 12:42 PM
zack22490
Apr 29, 2015 03:17 PM
