05 ignition issue - possible anti theft related?
I have a 2005 civic with a manual transmission and manual door locks. Today I drove my vehicle to work and home then back to work with no problems. After work I went to the post office and when I went to leave my key wouldn't move in the ignition. The key went in just fine and I could easily remove the key but it would not turn to start the car. The steering wheel wasn't locked and I was able to move it and move the wheels. it felt almost as if I was putting in the wrong key. Or like the steering wheel was locked to where I couldn't turn over the car. I have never had any problems whatsoever with the ignition until today. I ended up having to have the car towed to a mechanics. I had a new key made but it made no difderence. I recently had some issues with the driver side door lock, I think because somebody tried to tamper with the car and the anti theft system locked the door. Is it possible that the anti theft system that came stock on the vehicle is somehow is disabling the ignition?
Re: 05 ignition issue - possible anti theft related?
put the key in the ignition and open your door, do you hear the beeping alarm?
Sounds like....
Tumblers worn out in the ignition cylinder.
Drag it to your Honda dealer for rebuild. They should be able to fix the lock cylinder too, cylinders are in the same kit with the tumblers.
Dealer is the only place to do this in my town, local locksmiths don't have tumblers for Honda/Acura sidewinder keys.
Rebuilding allows you to use the same keys.
Most independent shops would just replace the whole ignition lock assembly and make you use multiple keys to operate the car (different keys for door/ignition) AND they have to tow it to the dealer to make it run (program the new keys)
OR they get a used set from the boneyard and a ECM that matches.
werdnahall
May 17, 2015 11:37 AM
Speedy
Jan 23, 2004 12:05 PM
RickSta
Feb 25, 2002 03:15 PM
CaptainAmerica
Jan 18, 2002 08:30 PM
