04 Civic dx conversion to HX trans
I bought this 5 speed Civic on the cheap because it needs a transmission. Is a HX transmission into a DX possible? Would be nice as a buddy has one cheap.
Re: 04 Civic dx conversion to HX trans
If you're thinking about an automatic trans, the answer is NOPE!
The HX used a CVT trans.
I doubt the manuals are a direct swap either, they have different part numbers and whatnot, like different gear ratios.
Thanks for the reply. I did not specify there at all. It is in fact a manual 5 speed. If the ratios are different that is what I would be after. I just need to know if it will be compatible or not.
You might check a local recycle yard (junkyard), use their Hollander interchange guide to see if they can be swapped.
I think the manual trans would bolt in without a problem, but the ratios will be a little different. Probably not a big obstacle, just different.
I talked to a guy and he said he is a 100% it will bolt up but cant say for sure about the axles(which isnt a huge deal) and what I am more worried about the shift linkage/cables.
usajags84
15
Aug 19, 2015 03:12 AM
oneheadlight
Apr 29, 2015 11:30 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
