Torquing lugnuts
Old Sep 25, 2014
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
Torquing lugnuts
Is it bad to do it with the car in the air? Almost every shop here torques your lugnuts with the car still in the air. THey dont bother lowering it first. They say it doesnt harm anything.
WIth the car in the air, wouldnt this mean that your wheels wouldnt turn as smoothly/fast? Since the weight of the wheel will be put on the lugnuts when its in the air.
Old Sep 25, 2014
Re: Torquing lugnuts
They are doing it right.
WUt? 0_o
If it's on the ground then you have 1500 KG of CAR sitting on them....as opposed to 15 KG of wheel and tire hanging in the air.
Besides, the weight of the wheel normally hangs on the hub when everything is right, not the lug studs.
If doing it in the driveway, I would only lower the wheel enough to keep it from turning while I torque the nuts. Not the full weight of the car on it.
Methinks you thinks too much sometimes.
Old Sep 26, 2014
I am Epic
WUt? 0_o
Okay, didnt know that if the car was on the ground and then the lugnuts torqued, the weight of the car is put on the wheels. Thanks for clearing it up.
I always thought the car had to be at ride height for the lugnuts to be torqued.
EdGasket
40
Nov 27, 2015 11:11 AM
rovafa2002
Sep 28, 2015 06:57 PM
WaryDriver
Aug 16, 2015 11:22 AM
logsplitter1
Aug 9, 2015 09:32 AM
breanna_17
Jul 21, 2015 04:01 PM
