Seatbelt buckle replacement question
Old Aug 24, 2014
taz_devil112's Avatar
taz_devil112 is an unknown quantity at this point
Hallo.
I have a 2002 honda civic lx that has the dreaded SRS light on.. i checked the code for the SRS problem and it was 9-3...
I've also tried the infamous trick of resetting the SRS through the yellow connector under the steering wheel but the light just comes back 1-2 weeks after..
I've decided to just buy a seatbelt buckle from the junkyard (a new one is hella expensive ...) and was wondering if I can use any seatbelt buckle from the 7th gen civics?? Or is there any codes/serial numbers that I oughtta look for in my car?
Thanks
Old Aug 25, 2014
lazlong's Avatar
Re: Seatbelt buckle replacement question
The buckles are the same for all 7th gens.
nationwide salvage listings: http://www.car-part.com/
Old Aug 26, 2014
Thanks. A local wrecking yard has em for 70 dollars.. I'll check em out
Old Aug 26, 2014
chris-02civic's Avatar
chris-02civic is an unknown quantity at this point
I just had mine fixed under warranty. My car is an 2002 Civic Ex with 176,000
Old Aug 27, 2014
Nice. Goodbye to SRS light
I'm canadian though so no luck for me for warranties.
Bought this car for $1100 with 227000 km (~140k miles?) on odo so im not really complaining ..
Only problems I need to fix though is the SRS 9-3 and some chirp around the serpentine belt. It's probably a loose pulley since it chirps whenever I put gas on. It's a good daily driver nevertheless.
bo_red
Transmission
May 3, 2015 09:14 PM
vtechcivic
Apr 21, 2015 06:58 PM
dano2005
Apr 14, 2015 01:58 AM
thesushiboy
Apr 12, 2015 02:54 AM
viper775
Dec 9, 2001 10:52 PM
