Driver window Down
Old Jun 6, 2014
Jay_Me's Avatar
Jay_Me is an unknown quantity at this point
Driver window Down
My driver side window on my 2002 civic went donw and will not go back up, I can hear the motor working when I hit the switch. any suggestions for what it might be? I took the door panel off of the door and can see the cable that runs to the motor and feel it move when the switch is pressed, is there a special routing for the cable that maybe it jumped a pulley? very annoying.
Old Jun 6, 2014
Re: Driver window Down
If the motor runs but the window does not move (and you hear crunching noises), you need a new regulator.
Old Jun 9, 2014
Red_Chaos1's Avatar
Red_Chaos1 is an unknown quantity at this point
This. My old Lincoln Town Car did this with both rear windows. My guess is that age or extra resistance cause the drive splines/teeth to chew up the pulley splines/teeth. The front passenger was worn too and would only halfway roll up, and the front edge of the window would catch on the guide or something. Would have to help the window the rest of the way up to get it fully closed. Replaced the regulator/motor with one out of another Town Car in a pick/pull yard and it lasted about a month before the pulley gave out in the same fashion. Had I and my friend that helped me had our druthers we probably would've done something to ease the windows movement along the guide.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
old97civic
Jun 28, 2015 10:55 AM
2HondaCivics
Jun 19, 2015 12:06 PM
timpan
May 18, 2015 07:06 AM
mwwhonda
Nov 7, 2001 07:24 PM
