Exhaust questions
Old May 21, 2014
drakers2's Avatar
drakers2 is an unknown quantity at this point
Exhaust questions
Ok so i have an 01 civic lx with a cracked manifold, id like to buy a after market one on ebay but cant really afford one, so i was looking at buying a used one from ebay but the used one generally dont come with the catalytic converter and im not sure if my catalytic converter is bad or not. Ive had a crack in manifold for a long time but the car recently got louder with more fumes entering the cabin. I took it to shop and they said they couldnt find any leaks that the manifold was getting worse. Thing is im scared to buy a used manifold without the converter, get it and them tell me my cat is bad too. How can i tell if my cat is ok and i can just buy the manifold by itself. When i look at the manifold it doesnt look any worse then it has for the last year, thats why im thinking maybe my cat has gotton bad which might explain why the car has gotton louder and im smelling more fumes now. idk.I cant really see the cat to examine it because of heat shield over it.
I basically only need this car for another 10 months and am looking for a cheap solution. Transmission on the car has been acting up for the last year so im only keeping it for a little while longer.
Old May 21, 2014
mikey1's Avatar
Re: Exhaust questions
if your CEL is not coming on and your engine is running fine, i would assume your cat is fine, if you dont need the car for that much longer i would just replace the header, why spend more money then nessessary?
Old May 21, 2014
GolNat's Avatar
Prelude Owner
If you have an Lx then the converter is built into the exhaust manifold. If you replace the manifold you replace the converter and visa versa. I would agree that the converter is probably ok if you do not have a CEL but the Lx has the "manicat" going on.
Old May 21, 2014
drakers2's Avatar
I looked at the headers on ebay but there not much cheaper then the manifold+ converter on there. And yes its an lx.
Old May 21, 2014
GolNat's Avatar
Prelude Owner
If you buy just the headers then you will loose your cat. CEL,failed emissions, pollution...
Basically your only option is to buy a converter/manifold. If you buy headers you will also need to buy a cat, which can be welded into the existing exhaust. Might as well just buy the manifold with cat.
Old May 21, 2014
Braze the cracks closed?
Old May 23, 2014
lowlife9's Avatar
brazing is just a baind-aid though it won't last very long then your back to square one. unless your just looking for a quick fix to pass emissions i would just replace everything.
Misfit2613
Jul 30, 2015 09:49 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
