Getting a loud whine when running defrosters and accelerating
Old Mar 20, 2014
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
If i dont do both it wont make the noise. I popped the hood and cant exactly tell where its coming from but i do know its from the driver side. But it gets louder as the rpms get higher. I turn on the reg AC button and some whine happens but when i turn on the rear defroster as well the whine becomes a lot louder.
Once i turn the desfrosters off, hit the gas and noise is gone.
Old Mar 20, 2014
Re: Getting a loud whine when running defrosters and accelerating
Might be alternator whine due to electric load, since you say the REAR defrost.
What about adding even more electric load, like headlights and blower fan? Noise gets louder?
Next try....
Make it do the whine noise. Unplug the big round connector from the alternator, see if the whine stops.
Is the alternator good or bad?
Old Mar 20, 2014
I am Epic
Next try....
I have a feeling its alternator whine but is it normal for them to whine when loaded? Also in cold weather? Not sure if temp makes them whine more.
I can test it again with the headlights on, but from what I notice so far the whine doesnt get any louder with more load.
When you say the blower fan, im guessing youre refering to the big fan under the hood? The one that spins when you run cold A/C or A/C defroster? If so, then no it doesnt get any louder when i hear that fan spin. I can be in park, have the defroster on, give some gas til i hear the big fan spinning and its the same noise level. I wonder why it only happens when i hit the gas.
Which big round connector do you unplug from the alt? What tool is needed or can i use my bare hands?
I did a load test a few months ago and the numbers were good. Should I do this again or is the test pointless?
I think the biggest question is whether it does this in warmer weather. It was really warm for a few days a couple days ago where i had the A/C running while driving but unfortunately i dont quite remember if i had any whine.
Thanks
Old Mar 20, 2014
CraigW's Avatar
sorry, i dumm
Old Mar 20, 2014
Yes.
Whine while trying to generate electricity is normal.
They get quiet when they are not trying to generate electricity.
HOW MUCH whine is the question.
I meant the one in the dash. The one you turn on with your right hand.
Nevermind.
Probably because the alternator RPM speeds up.
How many are there? Which one is the big one?
Bare hands.
What does "numbers were good" mean? What are the specs? What were the test results??
Was it making noise back then?
And pay attention to how much noise it makes while it's got a load on it.
Old Mar 20, 2014
I am Epic
Yes.
Oh didnt know that its normal for alts to whine when under load. Its just that ive never noticed it before and its noticable now. Its not super loud where the car in the next lane will hear it, in fact you can hear it better sitting in the driver seat than sticking your head under the hood. But its loud enough for anyone to be able to hear from inside. I know accelerating on the highway at 3000rpms today, it was pretty easily heard.
Remember when I replaced my battery and got boosted and drove to walmart? I said that I heard a easily heard whine from the alt? This is the exact same whine and from the same spot and same volume. Im wondering if i damaged my alternator from that 10min trip to walmart after I got boosted.
Had a feeling you were refering to this one. I will try it but I most likely wont be able to crank it to full as the fan noise will overide me hearing the whine from the drivers seat. Ill try it though.
oh
Im gonna look again but from what i saw earlier there was one thick one and a thin one. Was hard to see down there, will check again.
Um from what I remember it was 14.4V with car running and everything on (A/C, headlights).
No. I just noticed it in the past few days.
Described above. Not super loud enough to hear from the next lane but from the drivers seat its easily heard. Im gonna take it to one of my mechs tomorrow too and see too.
Old Mar 20, 2014
Your arm hurts after you slipped on the ice and fell today.
You had X-rays done on the same arm a few months ago when it didn't hurt.
Do you assume it's still ok now because it was ok then?
Apparently there's a problem now. Test it now.
Tough to say. I'd sorta expect it would have been making noise ever since that time if you damaged it.
Described above.
I did not mean now. I meant listen and observe during a real test.
When the test is performed, you start the engine and have all electrical loads turned off.
The alt should be relatively quiet since it isn't (shouldn't be) working hard.
The tech uses a VAT tester to manually control a large electrical load on the system, while measuring alternator output in Amps and Volts to make sure the alternator can sustain charging at its maximum output rating.
Listen to the alternator whine when the tester puts the load on it.
Also, it doesn't have to be the alternators' fault. A bad battery can make the alternator work itself to death too. Have your guy check everything.
Old Mar 20, 2014
cja3455's Avatar
cja3455 is an unknown quantity at this point
The defroster switch might be creating a short for you and that drains electricity like crazy putting big load on alternator, also did you check the pulley bearing those can cause whining as well and make sure the belt is adjusted and working properly
Old Mar 21, 2014
I am Epic
Ok
I see, ok ill get him to do that. Doesnt matter if the car has been driven and hot??
Thats actually what i was thinking too tonight. Could be the battery and putting extra load on the alt if its bad.
Old Mar 21, 2014
I am Epic
Hmm if there was a short, would it most likely be right at the switch? (behind the panel button). If so, i can pull the center console to check. I did have it out a couple weeks ago when i put in a new deck.
Ah yes, of course the pulley bearing and the belt. Ill put those on my list as things to check tomrw. thx
Old Mar 21, 2014
Stock 99's Avatar
Old Mar 21, 2014
I am Epic
well its the diodes in the alternator are starting to go. So looks like time for a new alternator.
The one now was an oem rebuilt one and only just over 2 years old. Paid $200 installed.
Mech says to put a new oem honda one im and itll last a lot longer. Said $380 for just the alternator. Thats alot.
Which should i do?
Old Mar 21, 2014
What does "OEM" mean in this statement? Was OEM the aftermarket brand or something?
Old Mar 21, 2014
CGaud's Avatar
CGaud is an unknown quantity at this point
Couldn't it just be a bad bearing or loose belt on the alternator? Maybe you are over thinking it.
Old Mar 21, 2014
CGaud's Avatar
OEM = Original Equipment Manufacturer
ie: "factory parts"... the parts originally used in the factory at the time the vehicle was built
Old Mar 21, 2014
I am Epic
I mean the alternator was OEM honda,died and then rebuilt
Old Mar 21, 2014
I am Epic
He said he was certain it was the alt. Wouldnt hurt to get 2nd opinion though. Wish i could do that 2nd opinion.
I find it hard to believe an alternators diodes starting to go at 2-2.5yrs time. Everything in it was replaced.
Old Mar 21, 2014
Bearing noise wouldn't be electrical load dependent.
Yeah, I know that.
I wanted clarification from the OP.
FYI there are cheapass parts stores (open on Sundays) that sell a brand name called 'OEM'.
Check it out here: http://www.oemautoparts.net/
Misleading from the git-go.
Seconded.
Depends on the quality of the parts that went in at the time of the rebuild.
There used to be a rebuilder in my town that used only the best parts. That guy retired and closed his shop.
All that's left here is one rebuilder that apparently uses the cheapest stuff he can get his hands on. Not even worth messing with, it's no better than the crapshoot that DangerZone is.
Old Mar 21, 2014
I am Epic
Im probably going to replace it in the next few days, dont want to take a chance with an alt thats on its way out. Last thing i need is to be stuck on the road and have to call a tow.
I would go new but $380 just for a new OEM Honda alternator sounds high to me. And thats through this mechs discount, otherwise he says its $480. Plus $100 install from him. Another factor is that the OEM Honda alternators are only 70 jules whereas the rebuilt ones are 100-110 jules. So i really dont want to pay $480 for a 70 jule alternator considering I have HID, sound system, etc, the more jules the better in my case.
Whereas rebuilt is $200 installed.
Im gonna call around more to these alternator shops. Of course they will all say that "yes we replace all the components and pieces in alts even if theyre still good" but like you said, its dependent on the quality of their parts. If this happened two weeks ago, I would say yes just go with another rebuilt and hope it lasts at least 2 years because I would probably have a new car by then. But since my parents bought a new car this week, chances of me getting a new car in 2 years is Id say zero since ill be paying my parents car every month for them.
Even though the mech today who checked it out is very good and reputable (hes not cheap) but he diagnoses stuff for me at no charge most of the time, I do want to get a 2nd opinion on it though. I dont want to replace the alt unless i know forsure its that.
Old Mar 21, 2014
Stock 99's Avatar
Personally I think OEM rebuilt is the way to go. I had a Toyota alternator rebuilt for me once and it lasted 10 years. I've always rebuilt my own starters and alternators since then.
If there's a Taylor Wilton near you ask them about rebuilding your alternator. I think they charge around $60 as long as you bring the in alternator.
Old Mar 21, 2014
I am Epic
But when you say OEM rebuilt, dont you mean that all the parts like the diodes, would have to be OEM parts?
I found a place that has a 90amp rebuilt one (OEM) for $95 with the exchange of me giving them my old one. Cheapest ive found so far and comes with 1.5yrs warranty. Nice.
Old Mar 21, 2014
Stock 99's Avatar
Sure, sure....
The rebuild on my Toyota starter was 2 L shaped chunks of copper that needed to be replaced...I didn't really care if they were Toyota copper or not. I believe I paid $10 for the 2 pieces. An OEM Toyota starter was about $500 a cheap one was about $300 and I was told it wouldn't last 2 years.
http://estore.honda.com/honda/parts/...b=E++0610&dl=#
I can't remember what Civic you have but if you're saying you need part #19 or #8 well I'd personally be hitting the wrecking yard for another alternator. Most commonly the brushes wear out in alternators (carbon). No need for them to be OEM unless it's an alternator that has the brushes inside a cartridge.
https://www.civicforums.com/forums/1...ttery-faq.html
Old Mar 23, 2014
I am Epic
Sure, sure....
Well I put in another rebuilt alternator yesterday from a different shop this time and the whine was still there. As suggested by another forum member on here, I started the car and unplugged the green plug going to the alternator. Whine was all gone. Tried it a few times to confirm.
So im gonna go back to the shop and work out something with the guy to get at least half of my money back. If he wants to do all the labour again to take his new one out and put my old one back in, fine but not at my cost. But it doesnt make sense for him since ill be replacing it in the next week anyways with a Honda one. Im hoping he can at least give me all my money back. Not my fault that his alternator is **** and i shouldnt have to pay labour for it.
Im gonna go back to the first mech and just get a new one Honda one put in. But you say i should just get one from the junkyard? Is a brand new Honda alternator overpriced at $380cdn? Whats the pros and cons getting a brand new one vs from the junkyard? Only bad thing is the junkyard one will have at least 5 years usage on it, if not more, all dependant on when the car was retired and scrapped.
I really hate how the honda ones are only 70amps as I would much prefer a high output one (the rebuilts are 90) especially if im going to be paying out of my *** for a new honda one.
Old Mar 23, 2014
mikey1's Avatar
certain parts i swear by going honda OEM, but an alternator is not one of them, i would go with an aftermarket alternator that comes with a lifetime warranty, cant go wrong there,
i would never get an alternator from a junk yard, its probably been sitting out in the rain for 3 years
Old Mar 23, 2014
I am Epic
So you dont think Honda OEM alternator is nessecary? Where can i buy a high quality aftermarket one cheaper than $380cdn? I would prefer one with more than 70amps just because i do believe i can benefit from one. I have HID and 700W RMS sound system.
I dont know how much Honda charges directly for the alternator (id imagine more than $380), but even at $380 it seems too much. Not sure how much markup my mech has on it even with his $100 discount that he gets it for. Im prettu sure most if not all mechs at shops markup their parts right? Especially big parts like this.
Old Mar 23, 2014
mikey1's Avatar
check out parts stores in your area, im sure you can get an aftermarket one for alot less than $380, and if you bring your old one in they will give you a further discount,
thats just my 2 cent opinion, if you want a honda alternator, then by all means buy one
Old Mar 23, 2014
Maybe it's normal. They DO whine when they are working.
So it's confirmed the whine is coming from your alternator.
But is it normal or not?
Factory remanufactured alt price $414 CN at torontohondaparts.com
(WOW you guys up there pay some high prices.)
I don't think brand new is available from Honda anymore, and it would probably be more than double that price if it was.
He had BETTER be marking up everything if he wants to stay in business.
Nobody goes into business to make friends.
Old Mar 23, 2014
Stock 99's Avatar
You have to do what's right for you. People come to forum boards to get different insights and opinions from other people to make more informed decisions about what they are going to do. What works for me may not work for you.
But you say i should just get one from the junkyard? Is a brand new Honda alternator overpriced at $380cdn? Whats the pros and cons getting a brand new one vs from the junkyard? Only bad thing is the junkyard one will have at least 5 years usage on it, if not more, all dependant on when the car was retired and scrapped..
I would get one from a yard if the price was right. A) because I would prefer to have original equipment and B) because I have the ability to disassemble and clean/inspect before I install. The downside of junkyards is generally no returns on electrical. I find most of the wrecking yards I deal with lately are every bit as professional as auto part stores and you generally are getting quality used parts at reasonable prices. My Civic is a '99 and it still has the original alternator in it after 15 years and 209k kms. When I bought the car I tried to get an extra set of brushes for it because I generally just carry extra alternator brushes and starter contacts in my tool box for when the day happens. I found it to be almost impossible to find brushes for my alternator and when I was asking opinion was that Honda alternators rarely fail. I don't know if that changed when the 7th gens were built but really I don't see any alternator questions in the forums for 6th gen.
I don't have a lot of options where I live to buy parts (Napa,Lordco,Canadian Tire, Taylor Wilton)....I've bought NAPA reman stuff before and it generally lasts a couple years. I've never seen a lifetime warranty on anything you can buy from NAPA.
HELL YA!!!!..............that's what I'm always saying
TiggerDX
Jun 18, 2015 01:43 PM
dinsum
May 28, 2015 09:30 PM
dooner24
Apr 14, 2015 07:51 PM
pheaton
Bolt-on Engine Performance
Jan 9, 2002 08:43 AM
clockwerx
Dec 13, 2001 12:39 PM
