Broken transmission pan bolt
I had some transmission fluid residue building up around the transmission pan bolts so I thought about giving them a firm tightening and one of the bolts broke with half of it remained inside. The doesn't seem to be any leak but is this gonna create a problem down the road ? Any suggestion on how to remove the other half of the bolt out ?
Re: Broken transmission pan bolt
Please post a picture of your transmission pan, then another picture of the bolt(s) in question, and another pic showing the relative area the problem is in.
here are couple of pics showing the broken bolt and where it came from. it is the bolt at the bottom of the transmission, the first one to the front. it's a corner bolt so it must be important. any suggestions ? I was thinking to put some high temp RTV silicon to seal the hole. The transmission fluid has 25k miles on it, does this get thinner with usage like engine oil ?, was thinking maybe i'll put in some new fluid in the transmission as well higher viscosity then Honda MTF 75w, maybe redline MTL 80W
I'd probably try a left-hand drill bit first, if there is sufficient room. If you are really lucky, the left handed bit would catch the bolt at some point and spin it right out.
Otherwise, I'd think the next choice to remove would be to drop the trans and split the case so it can be drilled out properly.
The hole itself really shouldn't be able to leak (the bolt is isolated away from the internally lubed parts), but the case mating seam it's clamping could leak. Or it could be leaking elsewhere and you just found the end result dripping there?
The trans oil only gets 'thinner' with temperature changes AFAIK, it doesn't get diluted with fuel and combustion byproducts the way engine oil can. It should be relatively stable (viscosity) throughout its expected lifespan.
I thought those were casting lines......
If they really are cracks, that might be indicating a much bigger problem.
Yes those are cracks but they just external not reaching inside the case to cause a leak and they been there for long time, maybe I should seal them with some jbweld or some sealer
The leak source looks like is coming from under the starter or under that part sitting next to it, I can't see clearly what's under there unless I remove the starter which I will do next, is there any transmission seal in that area ?
Does the trans actually lose fluid?
There's a whole lot more engine oil leak possibilities up there than trans leak possibilities.
I've had this happen before and it does cause leak. Fix it properly by using ezones method. If not maybe you can remove the transmission and replace the casing or at least find out what caused it.
Jul 12, 2015 11:54 AM
ballmich
Jul 9, 2015 11:59 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
