Interior dome and map lights not working
Old Feb 2, 2014
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
I put in a new dome light for the front, took the front and the rear dome lights out (currently had blue LEDs and want white). Put in the new ones and now none of the lights will work, not even the map lights. Ive tried putting in the LED bulbs both ways and made sure the connectors in the socket arent bent. Even tried putting my old bulbs in and they dont work either. Neither the front or the back dome light will work. WTF
What do i do now?
Old Feb 2, 2014
Re: Interior dome and map lights not working
Check the blown fuse?
Old Feb 2, 2014
#3, engine compartment box. 7.5 amp.
Old Feb 2, 2014
I am Epic
Thanks. I just checked, pulled the #3, 7.5A fuse and the metal piece inside it that goes from one side to the other, looks like its split. Im guessing its blown? If so, can i just buy any 7.5A fuse from the store? Im guessing theyre universal.
Old Feb 2, 2014
Replace with the same size, type, and rating.
Take your blown fuse into the parts store tomorrow and let them match it up.
Old Feb 2, 2014
You may want to get a box of them, you will probably blow several trying to make your LEDs work right.
Old Feb 2, 2014
I am Epic
Really? Oh didnt know LEDs blow fuses. Ill get a box, thx
Ya mine looks like the one on the left.
Old Feb 2, 2014
LEDs are polarity sensitive.
Research how a diode works and what it does, then you may understand why it can blow a fuse.
Old Feb 3, 2014
I am Epic
Oh I see, I have a question.
Im trying to find the right bulb for the rear dome but when I bought and tried to put in a 31mm Festoon DE3175 (what sites say is the size), its too short compared to what i have in now.
This is the bulb im trying to put in but it wont stay as its too short and too thin. I put in one bulb.
This is what I have in now
Old Feb 3, 2014
So....if it's wrong, it's wrong. Try again.
Unless you can make it longer.
Can't bend the tabs on the light inward?
Old Feb 4, 2014
I am Epic
Got it working, the rear dome is 44mm on the EX, not 31.
How do you swap out the trunk bulbs? I cant even find them and seems youhave to get a prybar to pull a huge metal piece off near the backseat
The site says the trunk is 168s, hope thats true.
Old Feb 4, 2014
Pop the lens assembly out of the shelf?
Look in your owners manual, maybe that info is there.
ORskier
May 3, 2015 12:54 PM
twtron
Apr 17, 2015 12:09 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
meels808
Nov 5, 2001 09:15 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
