Need help with Wheels
I have a 2002 Honda Civic DX with the stock wheels (Tire: P185/70R14) 4 Lug Pattern. I am planning to upgrade the wheels to a bigger size. Can i straight away install a 17" wheels or do i have to make some adjustments with the Suspensions too ??? Appreciate your input in detail if possible...
Re: Need help with Wheels
Yes you can go straight to 17's. Just match the lug pattern, and offset which will be around +40. You may also need hub centric rings if the wheels have a different diameter center.
