Help installing my first stereo
Old Jul 20, 2013
fuklotus's Avatar
fuklotus is an unknown quantity at this point
Hey guys I have a Honda Civic 2003 LX. I am pretty new at cars in general, I am pretty much a computer and phone kinda guy, so please bear with my noob knowledge. What I want to do is Install a new stereo into my car, i was looking at http://www.crutchfield.com/S-eDIOw8h...KD-X250BT.html I am ready to buy, I have been researching for hours about removing panel, but I see a lot of videos of people sauntering wires which really freaks me out. Would I have to do this or would it just be a plug in play and be a simple install. Also, do I have to buy a car installation kit? I eventually would want to install an amp and subs. Thanks a bunch if you guys could help me out.
Old Jul 20, 2013
GolNat's Avatar
Prelude Owner
Re: Help installing my first stereo
If you buy the adapter cables from Crutchfield then you will not need to solder the connections. They will provide an adapter that connects to the head unit and the OE wiring. You will need a DIN kit and those wiring harness for the instal. Later you can get an amp wiring kit when you are ready but since you have the radio out you might want to just run the wires for it, up to you.
Old Jul 20, 2013
fuklotus's Avatar
Thanks alot for the much needed info!
Old Jul 22, 2013
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
It's been a couple of years since I bought a head unit from Crutchfield but at that time they supplied a connector the matched the OEM plug and you had to connect it to the connector from the head unit. It is not necessary to solder the connections, you can use crimp connectors or wire nuts and tape. Most people prefer solder because it makes the best connection. As far as I know they will not provide a pre-made connector for JVC to Honda.
Old Jul 22, 2013
Kennykid2002's Avatar
Kenny the Ricer
Use butt connectors, I prefer that over soldering.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
