I broke something. Name this part.
Old Jun 20, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
I was using the DIY for spring install and noticed once I got everything out that some type of joint seems to have disconnected. The part circled in red-the boot part seperated from the bolt part. First-what is it, Second-how do I fix it?
Edit: Here is an actual pic
Old Jun 20, 2013
GolNat's Avatar
Prelude Owner
Re: I broke something. Name this part.
Front sway bar end link.
Buy a new one. Might as well do both
**I replaced mine and it really helped with the steering feel. Made the front end tighter.
Old Jun 20, 2013
got2run5's Avatar
What a pain. I can't do anything on this car without breaking something else. How am I supposed to get it in there? Right now I can't get the seperated cap over the top because it seems the sway bar is pushed down now. How about putting a jack underneath the sway bar to try to move it up an inch or so? Is this something that WAS broken/is it possible to break this during a strut install?
Old Jun 20, 2013
GolNat's Avatar
Prelude Owner
It was probably broken or weak. I had to use a bar to bend the sway bar down. My end links had 150k miles of rust. They were a PITA to remove.
If you have an impact gun they come off easier.
Old Jun 20, 2013
got2run5's Avatar
The parts stores must love me, I just keep finding things to replace Might need a new tie rod end too because I was stupid and pounded on it a little bit when it wouldn't pop out.
Old Jun 20, 2013
lowlife9's Avatar
or you could just remove the swaybar all together.alot of people prefer the feal better without it.
Old Jun 21, 2013
GolNat's Avatar
Prelude Owner
^ forgot about that. The ride is softer without the sway bar. It will give you more oversteer also. I rode a couple days without one but after I installed new ones the steering was so much more crisp and responsive. May have been from going from no sway to having one again that made it feel better.
I ended up needing new tie rod ends also. I put pep boys ones on there and they are already shot. Ill be putting on either ingalls or moog when I replace them again. They should hold up better to a lowered suspension.
Old Jun 21, 2013
got2run5's Avatar
Supposedly Oreilly's offers some that have a lifetime warranty. Not sure how they can make money off that but I think I'll try it out. They're much more friendly and helpful than the local Advance Auto I always shop at.
Old Jun 21, 2013
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
When you install the end links make sure both wheels are in the same position, either both on the ground or both in the air. If you only have one side jacked up and other is on the ground it will be difficult.
I believe the threaded bolt on the end link also has a place for a hex key on the end. Use a hex key to keep the bolt from spinning and tighten the nut with a wrench.
Old Jun 21, 2013
remove endlink from the other side and the sway should move freely...
Old Jun 21, 2013
lowlife9's Avatar
you could give these a try
http://www.corsportusa.com/store/cat...ducts_id=11594
Old Jun 21, 2013
got2run5's Avatar
Put a wrench on the nut and it was so rusted that I almost rounded the edges on the first try. Decided I didn't want to have a fun time cutting off the bolt, so found a local shop that would install it for $20. Call me lazy, but I can deal with that. Just have to put the rest of my suspension in first.
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
tavisc
Sep 15, 2015 07:46 PM
aaronmechanx
Sep 14, 2015 08:45 PM
