[SOLVED] Car battery replacement.
Old May 21, 2013
novice121's Avatar
novice121 is an unknown quantity at this point
Quick noob question here. I need to replace the battery on my 2001 EX, I can't find much on google, and only a 51 part number reference.
Anyways, I had no warranty, and the last time it was installed by Autozone.
So I wanted to try the 3 year free replacement deal I saw on Wal-Mart, and when I got the, the sells rep' gave me one woth part number 51r-4, so I didn't think much of it, and it seemed the right size, plus he seemed knowledgeable when he told me the 2001 civics with 4 cylinders needed to have the polarity with the positive on the left, and negative on the right.
However, as soon as I get home, I see that I have a battery part 51-1 with the negative on the left, and the positive on the right.
Didn't try to replace it, should've asked or done some research first, but I didn't, like a dumbass, so here I am.
Any help?
PS: New battery is from EverStart 51r-4 / cold crancking amps 500 / selection number 36
Old battery from Autocraft 51-1 cranking amps 530
Old May 21, 2013
cja3455's Avatar
cja3455 is an unknown quantity at this point
Re: Car battery replacement.
You can check the correct walmart battery size for your vehicle in this site http://www.championandeverstart.com/
Then click on battery finder and enter your vehicle
If the wires are flipped you can flip the battery facing backward, they should install it for free if you buy it from them
Old May 21, 2013
novice121's Avatar
Thank you! That link gives me the same battery, so I guess I'll try putting it backwards... it's weird it'd be like that, but I'll try.
Old May 21, 2013
GolNat's Avatar
Prelude Owner
You can try to flip the battery but the hood prop might hit the terminals. Just take it back and get the correct one.
Old May 22, 2013
novice121's Avatar
Solved. The link given by him gives the correct battery. It was supposed to be 51-4 and not 51r-4, to avoid the switch polarity issue . Thank you very much.
CarStuff
Dec 6, 2020 12:52 PM
roverben
Jan 21, 2019 05:16 PM
tylerginevan
Apr 27, 2015 12:29 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
SSMatey
Apr 13, 2015 06:09 PM
