How to remove the crank pulley bolt in less than 5 seconds
Old May 12, 2013
scooty's Avatar
scooty is on a distinguished road
I recently bought one of these to make removing lug nuts easier.
I just did a head gasket, and it zipped the crank pulley bolt out like it was nothing! No need for elaborate breaker bar, support and cheater bar setups or that crazy expensive pulley holder tool from Honda.
It's less than a $100 at Sears and I find my self using it a lot. just thought I'd share...
Old May 12, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: How to remove the crank pulley bolt in less than 5 seconds
Glad it worked for you. It probably won't work for most others though. Since when is a breaker bar elaborate lol (not trying to be smart)
Old May 12, 2013
mikey1's Avatar
if that drill loosened the crank pulley bolt, then it was not tight enough to begin with, and how are you going to torque the pulley bolt when you put it back on?
Old May 13, 2013
scooty's Avatar
A breaker bar by itself is not elaborate, but when you need a:
1) 24" extension to get the breaker bar to reach all the way to a socket on the crank pulley so you can clear the fender to turn the breaker
2) Support the extension where it attaches to the breaker by using a jack stand so things don't twist in the wrong plane and strip the socket off the pulley bolt
3) A tool to hold the crank pulley from turning, such as Honda's expensive tool, a chain wrench or a screw driver wedged some where
4) A pipe for additional leverage on the breaker
....things get elaborate and complicated.
Old May 13, 2013
scooty's Avatar
It's not a drill.
It is an impact driver with 130 Ft Lbs of torque.
Torque to correctly install that bolt is a lot less then what's required to remove it. The engine rotates counter clockwise. That naturally tightens the bolt over time in addition to whatever the factory torques it to.
Old May 13, 2013
BlueEM2's Avatar
Whachya lookin at?
Torque spec if I remember correctly is 15ft/lbs and then another half a turn. This won't work for most people, but hey if it does all the power to em. People have tried removing this bolt with 400ft/lb + air driven impact drivers with no success. Good post nonetheless, especially if it saves a bunch of people some trouble.
Old May 13, 2013
Isn't the *actual* torque spec 181ft-lbs?
Old May 13, 2013
BlueEM2's Avatar
Whachya lookin at?
Maybe, never seen the actual torque spec. I just remember the half turn thang.
Old May 13, 2013
mikey1's Avatar
yes that is correct
Old May 17, 2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Says 400 and actually is are two different things Must have been a junk impact, If that bolt was tighter than 400 ftlbs it would snap...
Old May 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Yea, rusting and seizing over time, plus spinning in the direction to tighten it. I'm just going by what I heard. I used a breaker bar to break them free. I see what your saying about the bolt breaking though.
Old May 18, 2013
rjones7755's Avatar
Yeah im honestly shocked that got it off, ive used a 300 ft/lb air impact that couldn't get it off lol
Old May 21, 2013
lazlong's Avatar
Not quite that much:
Old May 21, 2013
BlueEM2's Avatar
Whachya lookin at?
^ Yea, that's the proper way.
Old May 21, 2013
04 Honda Civic's Avatar
Wow you were lucky to get it off with that.
I had my older blue point air impact gun with around 100 pounds at the tank and it didn't work..
GolNat
Suspension DIY
May 12, 2022 06:49 AM
LionSpratt
Jan 29, 2017 11:07 PM
JAMorganIII
23
Jul 4, 2015 11:52 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bluecoupe
Dec 20, 2001 07:12 PM
