2003 civic sport
Old May 10, 2013
blues99man's Avatar
blues99man is an unknown quantity at this point
2003 civic sport
Hi All, hoping to learn lots in this forum. Wondering if anyone can tell me what the stock engine would be in this particular canadian vehicle and if it possible to swap the engine and tranny out of this model and put in an engine and tranny that was make in Japan, and if so, what engine would be the best. Thanks in advance for any comments.
Old May 10, 2013
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
Re: 2003 civic sport
what car is it? if its a 7th gen its a d17 and to swap you could put a k20 in it or if its 6th gen its still a d series i believe and the performance engine would be b16 or b18
Old May 11, 2013
blues99man's Avatar
Not sure if that was enough info, I only know thats its a 2003 civic sport, was wondering if a japanese engine would fit.
Old May 11, 2013
mikey1's Avatar
what exactly do you mean by "japanese engine"?
Old May 11, 2013
paulymcd7's Avatar
can you give us a picture? or actually look at the driver side of the windshield at the very bottom there is the VIN the 4th 5th and 6th digits are your chasis code, if you could tell us those we can help
Old May 11, 2013
BlueEM2's Avatar
Whachya lookin at?
D17A1 guys, non vtec. Yes, a JDM engine will work. As long as it's a direct replacement, JDM D17A1. Check your valve cover, if it says "Vtec" on it then its a D17A2, if it says HONDA its a D17A1. If you want to be 100% sure, there is also an engine code imprinted on the block, below the water hose, ish.
Old May 11, 2013
blues99man's Avatar
I just got the vin# 1hgfm229331802595, this surprises me here in canada, does that first number mean it was built in america. Thanks for the comments.
Old May 11, 2013
mikey1's Avatar
chances are if it was built in america your speedo would be in MPH not KPH
Old May 11, 2013
blues99man's Avatar
I've never seen the vehicle, its something a family member just wants to send to the scrap yard, I guess they blew the head gasket and the dealership said it would be $2k for sure to fix. I just wondered what kind of options I might have for engines and their availability, before I towed it anywhere. It may simply be a head gasket problem, but I was told it was overheating for quite some time so there could be much more damage. Again thanks for the comments.
Old May 12, 2013
SOLD, not built.
Cars are built to be sold in a certain market.
Cars can be built to be exported.
We have plenty of cars sold in the USA that were built in Canada (all VINs that start with #2), yet they have MPH speedometers if designed to be sold here.
Also look on the emissions label under the hood. Does it say Federal or Canadian emissions? Is the label in French?
There are more differences (DRL, SRS etc.), but that's what the average person will see.
Yeah, they blow head gaskets. Common.
If it has been overheated many times, it may just be safer to drop in an engine than to fix the head gasket, as you are already planning. You really should do all you can to freshen up a used engine before it goes in though (maybe including a head gasket). Little more expense, but it's a whole lot easier while out of the car, and good peace of mind.
You can get a used engine for $500 or so, and drop it in DIY dirt cheap.
www.car-part.com
Probably have it running and driving for $7-800 total if you DIY everything right.
Shine it, flip it, make a grand?
Old May 13, 2013
blues99man's Avatar
Thank you for the comments everybody, I wonder if there is somewhere on the net I can find a decoder for that 2003 vin number. Certainly is lots of info on this site regarding repairs for this vehicle.
Old May 13, 2013
jedema's Avatar
jedema is an unknown quantity at this point
http://www.vindecoder.net/?vin=+1hgf...&submit=Decode
should be what you need. Looks like you have the VTECH so it is probably the D17A2. Watch those JDM motors however. they are frequently listed as A2's but if you look at the number it is just the D17A which is different. Make sure you get the A2
I'm just starting a similar process. Picked up an 02 EX with a large hole in the engine (rod) for $800. Picked up an 05 motor with 75K on it and am working on refurbing the critical parts (timing, WP, tensioner, random gaskets etc..).
Old May 13, 2013
You sure it doesn't say 1hgem2? Especially for a 2003, em2 would denote that it's a 01-05 coupe. Also, yes, a VIN starting with "1" means it was built (i.e. assembled) in the US. 1,4,5 means assembled in the US, 2 - canada, 3 - mexico, J - japan.. That's all that really means. Doesn't really have any effect on if a [enter country name here] engine will work, so long as it's a D17xx (-a1, according to Tom [BlueEM2]). It also won't denote that the speedometer will be in KPH or MPH, since, like ezone said, cars are built to be sold in certain markets.
If it is, indeed, a d17a1, trying to swap in a D17A2 will require a bit more effort, pretty much to control the VTEC aspect of the engine.
edit:
Running that VIN with the "corrected" EM2 in the "chassis code" position, it shows that it's an automatic USDM EX coupe (CDM Si coupe), so your engine would be a D17A2, not the aforementioned D17A1
Old May 13, 2013
1hgfm229331802595 VIN is invalid.
1hgem229331802595 VIN is still invalid.
OP: try again.
Old May 13, 2013
BlueEM2's Avatar
Whachya lookin at?
The 2003 honda civic "LX" Sport in Canada has a D17A1 engine, I told him how to check to make sure.
Old May 13, 2013
I don't remember that we ever got a "sport" version of the car in the US.
Must be Canadian market?
A valid VIN should tell that part of the story.
Old May 13, 2013
BlueEM2's Avatar
Whachya lookin at?
It's definitely a Canadian market car I don't think much is different from a standard LX except the rims and a spoiler, maybe a couple other things.
Old May 13, 2013
OP: try again.
http://www.hondaautomotiveparts.com/...em229331802595
Old May 13, 2013
Is that even accurate? Majestic calls it a 2dr EX, the discussion above says it is a Canadian (LX) Sport. Not the same?
Majestics' site isn't actually checking the VIN as a complete number (I've run into that before).
It's only telling what the car is based on the first section. It's not actually checking for a valid US market VIN.
Here's an invalid VIN, all zeros for a serial number: http://www.hondaautomotiveparts.com/...l=&inputstate=
The car is a Canadian market car, if the above conversation is accurate.
The VIN does not work at http://torontohondaparts.com/
The VIN does not work in my VIN report through Honda USA.
If you want to check a US VIN, try it on this site estore.honda.com/
Still need OP to give the correct VIN!
LOL
Old May 13, 2013
Touché
I'm just working with what we're given. Extrapolating data that isn't there. haha
Old May 14, 2013
blues99man's Avatar
Ok, I was being fed bad info, I picked up the vehicle this morn, its an si with a 1.7 vtec engine in it, underneath the hood their is canadian markings, but inside the driver door panel it says made in america. He told me it would not run for more than 5-10 minutes without overheating. After I got it home I took the rad cap off and put in about a litre of fluid over 5-10 minutes of burping, filled the overflow reservoir and ran it for an hour with the two fans kicking off and on and no overheating. Looks like abit of engine oil leaking somewhere on the engine. No antifreeze in the oil. (220K) Perhaps I still have a slight leak at the head gasket, compression test tomorrow. Tough world out there for peeps with no clue about cars. Thanks everybody, will check out some of those links.
Old May 14, 2013
French hood sticker says it was built for the Canadian market.
Enter the VIN into the Toronto Honda parts site. If it accepts the VIN, it is a Canadian market car, no matter where it was built.
I'd expect a head gasket leaking, and probably a warped head since it overheated.
If you drive it for a while, it will push enough fluid out of the radiator to overheat again.
This test will not show a head gasket leak on this engine.
EDIT: Found the video here: https://www.civicforums.com/forums/1...ml#post4629441
Read a few posts back in that thread so you see how we got to this point.
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
deus-ex
Apr 13, 2015 12:29 PM
