noobie driver rev help!
Old Apr 26, 2013
cona's Avatar
cona is an unknown quantity at this point
i wanted to rev my car, but the pavement was on a slant so i put the clutch in and put it in neutral. i then kept the clutch in and reved it to about 3-5k rpms about 3 times
did i burn my clutch badly?
is that something really bad to do?
agh im really worried.
please give me some feedback
regards,
cona
Old Apr 26, 2013
Re: noobie driver rev help!
If this is true, then "no harm, no foul".
OTOH, slipping the clutch excessively is bad.
Old Apr 26, 2013
cona's Avatar
what do you mean by slipping the clutch?
when i shift gears, i usually put some gas with releasing the clutch to make the ride smoother.
im assuming i am slipping the clutch
how can i drive smoother without doing that?
Old Apr 27, 2013
jus' go out and drive...
Old Apr 28, 2013
maxtierney's Avatar
EM2ti
You were in neutral, with the clutch in (engaged) and then you revved? No harm, really. Why not let the clutch out and rev? Same result. Now putting it in gear and dropping the clutch (disengaging quickly) or slowly letting it out (slipping) with the revs high, isn't good. This would take some life out of the clutch, but only if you do this often, should you worry.
Old Apr 28, 2013
cona's Avatar
thanks man
having the clutch in in neutral is alright because thats how you rev match! i forgot! and i just learned heel toe. went out and practiced it for 30-45 min.
now i see why they say that the ep3 is a fun car. im having a blast
orangeju1ce
Jul 14, 2015 08:32 PM
ballmich
Jul 9, 2015 11:59 AM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
cgavin1
Jul 7, 2015 07:10 AM
Spanky4269
Jul 5, 2015 09:40 PM
