Faulty A/F sensor 1
I went to Autozone for a test due I have a light on "check engine and maintenance req'd; the test came with a Faulty A/F sensor 1. What does that means?.
One more: Can I purge the power steering fluid?
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Re: Faulty A/F sensor 1
Air/Fuel sensor, Means your O2 sensor is bad.. I beleive the 1 is telling you its bank 1 which would be your "upper" sensor.
I wouldn't call it a purge, but yes you can do a drain and fill of your power steerig fluid. What year is your car?
You're right I should drain the Power Steering fluid, I need it because I put Brake Fluid by accident and I think it's the reason I got a noise in the steering.
Regarding the O2 sensor you think it's possible to change it by myself or required an specialist?
Thanks again,
Yes you can do it yourself, You can you tube it and probly find 1000 matches, I have not checked the site but thier may be a DIY on here as well. If not just google search it.. Its pretty simple..just a PIA to get to sometimes.
Do the same thing for the fluid..tons of videos on that to.. and it only takes about 15 mins maybe 30 at most.
Green02civic
Jul 27, 2015 10:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
cizsak
Jul 21, 2015 03:39 PM
