No Gear Pattern, Please Read
Old Feb 25, 2013
Winslow11's Avatar
Winslow11 is an unknown quantity at this point
Okay, so my friend called me this morning in need of my help with his 03' civic. I am a Prelude owner so he thought I might have an idea of what to do. He had his car parked on an incline and had trouble putting it into reverse so he pulled a little harder than normal to get the transmission (5 speed) to shift back into reverse and when he pulled there was a pop. After the pop he couldn't put his car into any gear. His car no longer has any gear pattern at all. You can move the shifter in a circle or where ever you want and not catch anything. He did mention that his shifter has tension from left to right, but no tension forwards and backwards. For as long as I have worked on vehicles I have never heard of anything like this. So if anyone has any idea at all it would be much appreciated. Thanks for your time.
Old Feb 25, 2013
mikey1's Avatar
Re: No Gear Pattern, Please Read
something has come loose or disconnected between the shifter and the tranny.....you are going to need to jack the car up, crawl underneath, and inspect
Old Feb 25, 2013
GolNat's Avatar
Prelude Owner
You inspect the shifter cable from the top of the car. If you remove the center console you will find 2 sets of cables leading to the tranny from the shifter. Check the connections at the shifter and the connections on the top of the tranny. Sounds like the cable or shifter broke.
You can see the cables a little here:
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
