getting my DIY's crossed
Old Feb 18, 2013
Brooks952's Avatar
03 Civic EX
Brooks952 is an unknown quantity at this point
I'm going to be conducting a timing belt change and along with it a coolant flush. I seem to remember at some point reading about some engine mounts people on this forum suggest, I assume this would be a good time to swap those? I'm also planning on throwing in a Crower Stage 1 cam that will go along with this process. Is there anything else I'm forgetting that should be done along with this. I feel like I've read about 100 DIY's on here this year and can't remember which I was all going to do at the same time, thanks.
Old Feb 18, 2013
Re: getting my DIY's crossed
after you swap the stage 1 in, do the https://www.civicforums.com/forums/1...djustment.html to crower's specs: .006" intake and .008" exhaust (adjusted cold)
Old Feb 19, 2013
mikey1's Avatar
depending on the mileage of the car, other things to consider.....
- water pump
- timing belt tensioner and spring
- cam seal
- crank seal
- thermostat
- valve cover gasket
Old Feb 19, 2013
Brooks952's Avatar
03 Civic EX
- water pump
- cam seal
- crank seal
- thermostat
Those items will definitely be done with the timing belt, thanks
Old Feb 19, 2013
Brooks952's Avatar
03 Civic EX
Definitely going to happen, I'm going to follow the DIY's I have saved, i.e. stage 1 install, timing belt, coolant flush. I'll probably get the valve cover painted/powder coated. I guess my question should say "while I have everything off are there other things I should be taking care of?
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
curaze
Sep 22, 2015 08:27 AM
Trennytrent
Jul 10, 2015 09:01 PM
